shaky Posted November 8, 2011 Share Posted November 8, 2011 Are the original seats linked into the car's airbag system? would then disconnecting them may bring a warning light on ?? Quote Link to comment Share on other sites More sharing options...
SteveC Posted November 8, 2011 Share Posted November 8, 2011 The seats are not connected to the air bag system. If you've had the dash off and turned the ignition on, then I recall that can make the air bag light appear. Quote Link to comment Share on other sites More sharing options...
nevins Posted November 8, 2011 Share Posted November 8, 2011 Seats are linked to the air bag sorry to say. As the pretensioner is fired the same time as the bag to pull you back into the seat. Quote Link to comment Share on other sites More sharing options...
shaky Posted November 8, 2011 Author Share Posted November 8, 2011 Ok thanks,not had the dash out so i have a problem,i'll try the 2 wire trick Cheers!! Quote Link to comment Share on other sites More sharing options...
nevins Posted November 8, 2011 Share Posted November 8, 2011 Check that the plugs for the pretensioner are fully connected, common problem is where the esat moves forwards and backwards, or stuff goes under them it pulls on the wiring. Quote Link to comment Share on other sites More sharing options...
nevins Posted November 8, 2011 Share Posted November 8, 2011 Also a trick to get a light out is to fit either a 2.4 or 2.7 ohm resistor in the plug, can't remember which one though. Quote Link to comment Share on other sites More sharing options...
SteveC Posted November 8, 2011 Share Posted November 8, 2011 (edited) Seats are linked to the air bag sorry to say. As the pretensioner is fired the same time as the bag to pull you back into the seat. Are you absolutely certain? I checked on the diagrams I have before replying and there was no mention of any connection to the seats. Edit: Diagram of layout of associated components of SRS system added.SRS Diagram.pdf Edited November 8, 2011 by SteveC (see edit history) Quote Link to comment Share on other sites More sharing options...
shaky Posted November 8, 2011 Author Share Posted November 8, 2011 Seats are linked to the air bag sorry to say. As the pretensioner is fired the same time as the bag to pull you back into the seat. Will the wire trick work then? i have put recaros in, had a good look at all the wiring and all seems fine,2 plugs on the left seat and 1 on the right Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted November 8, 2011 Share Posted November 8, 2011 Yeah, the 2 wire trick will work. I have bucket Recaros in mine and no air bag. If you disconnect the panel with the warning light at any point, then you will need to reset using the 2 wire method. Quote Link to comment Share on other sites More sharing options...
