1UZFE Twin Turbo Conversion Kit for Supra
Ryan.G
2 power levels available
1. 550bhp kit with VNT25 Turbos
2. 750bhp kit with GT28RS Turbos
1UZFE Supra conversion bits (Custom Billet Flywheel, Adaptor plate for v160 or W58, Soarer Sump for sump clearance, Custom Engine mounts, Oil cooler and Filter take off and powersteering pipes)
1UZFE Twin Turbo kit (2x Garett VNT25 turbo which produce 550bhp or 2 x Gt28RS turbo good for 750bhp, Exhaust manifolds, downpipe, external wastegate setup, turbo blankets, all oil feed and return lines)
Intercooler kit with Supra Fitment and all hard pipes
Alloy Radiator to fit with Twin Turbo kit. Had Pacet fans fitted (£90 each!)
Both Packages are available at £2500!!
Bargain of 2012!
  • 2 weeks later...
  • 1 month later...
Would it just drop straight into a TT6 Jspec
You would need an engine to fit the kit to, Noel (nur motorsport) has a load of them at his garage.
Pretty much, you would need a bell housing adapter with a 6 speed though (which Ryan had iirc)
Its included in the kit.
  • 3 weeks later...
  • 2 months later...
http://i14.photobucket.com/albums/a346/Fletchy/SAM_0356Medium.jpg
http://i14.photobucket.com/albums/a346/Fletchy/v8bits001.jpg
http://i14.photobucket.com/albums/a346/Fletchy/v8bits003.jpg
http://i14.photobucket.com/albums/a346/Fletchy/v8bits002.jpg
Bargain of 2012!
Ryan
Would it be possible to "customise" the kit? I wouldn't mind getting the like the turbo kit at some point, but I wouldn't have any need for the adaptor plates or the sump as I'm planning on nabbing bits from my Soarer and keeping the auto box.
This is just food for thought on my behalf so I can justify the budget to my wife, when the time comes... :sly:
Hi
If you want the turbo kit and then 2soops wants the other bits im happy for this to work.
Best if you called tomorrow to go over more as im on mibile internet at moment away
Ryan - 07812786303
Ryan
