Chris Wilson Posted March 29, 2015 Share Posted March 29, 2015 Hmmm, is there some particular reason they use seven bolts? As the crank flange has eight holes this sounds a bit odd.... Link to comment Share on other sites More sharing options...
Jellybean Posted March 29, 2015 Share Posted March 29, 2015 (edited) Hmmm, is there some particular reason they use seven bolts? As the crank flange has eight holes this sounds a bit odd.... Must be a mistake on the website OsGiken say use OsGiken bolts or mod the JZA70 bolts; I read the bolts required are shorter than OEM http://www.osgiken.net/upload/d42.pdf Edited March 29, 2015 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
ManwithSupra Posted March 30, 2015 Author Share Posted March 30, 2015 With a stock Giken movement alteration kit the pedal is virtually the same as a stock clutch. It'll probably be lighter still with the concentric release. There may be need for some experiment by Richard with master cylinder sizes, I suggest starting with a 3/4 inch bore one. Clutch is a TR2CD. Yeah, I am going to check to see what I have installed already tonight. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 30, 2015 Share Posted March 30, 2015 I think I mentioned this to you, but you must use a pedal stop with some cylinder sizes, depress slowly and carefully until the clutch fully releases, if the pedal (and thus master cylinder) still has much travel left you MUST fit a stop or the diaphragm spring will be damaged. I suggest an adjustable stop. Link to comment Share on other sites More sharing options...
ManwithSupra Posted March 30, 2015 Author Share Posted March 30, 2015 I think I mentioned this to you, but you must use a pedal stop with some cylinder sizes, depress slowly and carefully until the clutch fully releases, if the pedal (and thus master cylinder) still has much travel left you MUST fit a stop or the diaphragm spring will be damaged. I suggest an adjustable stop. Yep, I already have an adjustable pedal stop Link to comment Share on other sites More sharing options...
chazuk Posted May 1, 2015 Share Posted May 1, 2015 Any updates mate ? Link to comment Share on other sites More sharing options...
mattdavies Posted May 1, 2015 Share Posted May 1, 2015 Any updates mate ? From his Social media it appears he has been in Asia on holiday Link to comment Share on other sites More sharing options...
chazuk Posted May 1, 2015 Share Posted May 1, 2015 From his Social media it appears he has been in Asia on holiday Eh no time for that when there's a sequential box waiting to get a thrashing Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 3, 2015 Author Share Posted May 3, 2015 Hey guys, sorry for the lack of updates as others have already stated I have been on holiday in Asia namely North and South Vietnam and Cambodia. Its full steam ahead as from Tuesday so updates will be coming through again. Link to comment Share on other sites More sharing options...
supra matt Posted June 16, 2015 Share Posted June 16, 2015 Any updates mate you been for a road test yet? Link to comment Share on other sites More sharing options...
T2 MSW Posted June 16, 2015 Share Posted June 16, 2015 You doing Oulton TA on the 11th July?? Link to comment Share on other sites More sharing options...
ManwithSupra Posted June 24, 2015 Author Share Posted June 24, 2015 Sorry for the lack of updates guys, been focused on my new business recently, its been a busy few months Also had a nightmare with the prop shaft took an age to get to me so that put me massively behind as well Car is still getting there, spent a good amount of time on it today finishing off the harness mounts and seat sub frames as some things needed adjusting, will be spending all day tomorrow and all day Friday installing all the new electrics and looms so it should be up and running very soon, testing will follow so I will keep the updates rolling in. I think its safe to say that getting to the next round of Time Attack could be slim, that said things are coming together now I have a bit more time to spend on it. Here is a picture of how it is at the moment, I know you cant see much has changed but there has been an awful lot of work done on the wiring looms, pneumatics, brake lines, brakes master cylinder, wheel bearings, cooling etc parts you cannot really see. https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/19597_835735896501055_6145574716872535795_n.jpg?oh=03db44c065156be5223fa1db7097aa4e&oe=562CF4FE https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xta1/v/t1.0-9/11267103_835735983167713_3951934775792068301_n.jpg?oh=dd2c2b3bab791bfd79e61fe00613512a&oe=5626542C https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/11540842_10153080662883802_5523674631581637931_n.jpg?oh=d670ff5173a98a0a9952c0260d1e38b1&oe=5632023F Link to comment Share on other sites More sharing options...
Luxluc Posted June 24, 2015 Share Posted June 24, 2015 That Supra is pure sex. Link to comment Share on other sites More sharing options...
ManwithSupra Posted June 24, 2015 Author Share Posted June 24, 2015 Thanks man Link to comment Share on other sites More sharing options...
T2 MSW Posted June 25, 2015 Share Posted June 25, 2015 Looking good, shame about TA but there is always next year. Maybe do a OHW that last event of the year - not sure when or where that is. Get yourself into it. Link to comment Share on other sites More sharing options...
ManwithSupra Posted July 3, 2015 Author Share Posted July 3, 2015 As I have had a good day today I treated myself today to a new Lid Very much in keeping with the new look of the car Lovely and light too Link to comment Share on other sites More sharing options...
Jellybean Posted July 10, 2015 Share Posted July 10, 2015 Forgot to ask, what happened with the guy in work who taught he knew everything about Supras and then found out you race one Did he come back in after that cigarette lol Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 10, 2015 Share Posted July 10, 2015 As I have had a good day today I treated myself today to a new Lid Very much in keeping with the new look of the car Lovely and light too And a fantastic price for a carbon lid to boot! New website is top drawer mate. Link to comment Share on other sites More sharing options...
ManwithSupra Posted July 10, 2015 Author Share Posted July 10, 2015 And a fantastic price for a carbon lid to boot! New website is top drawer mate. Ah cheers, yeah the price is amazing on those helmets they are very comfortable. Thanks with regards the site, there is a load more stuff going on soon too - - - Updated - - - Forgot to ask, what happened with the guy in work who taught he knew everything about Supras and then found out you race one Did he come back in after that cigarette lol I dont ever remember seeing him after that day no. Link to comment Share on other sites More sharing options...
chazuk Posted August 15, 2015 Share Posted August 15, 2015 How's it going mate any updates ? Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 28, 2015 Author Share Posted August 28, 2015 How's it going mate any updates ? Sorry dude, haven't checked in for ages. Yeah its getting there, been pretty much 100% commited to my new business so this has had to take a bit of a back burner. Latest update is that I needed to get a custom extention harness made up for the Syvecs ECU as the area where the ECU is located on the car is so hard to get to and that there is so little loom to play with, splicing in the Geartronics ECU would be near impossible. Now JTI made us up the new extention harness means I can plumb in the geartronics gcu without having to be a contortionist, lying upside down with a red hot soldering iron an inch from my face with boiling solder waiting to drip on me. Yay for me and for my face... https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xlp1/v/t1.0-9/11217509_886063341468310_5947080742711194361_n.jpg?oh=651751c0e9bb436b9971f66f4f6ec304&oe=567CC62D Link to comment Share on other sites More sharing options...
paulj1 Posted August 28, 2015 Share Posted August 28, 2015 Any chance you'll be at the final round of time attack at rockingham in 3 weeks time? Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 28, 2015 Author Share Posted August 28, 2015 Any chance you'll be at the final round of time attack at rockingham in 3 weeks time? I seriously seriously doubt it Link to comment Share on other sites More sharing options...
paulj1 Posted August 29, 2015 Share Posted August 29, 2015 Shame that trying to get a club stand there but no one seems interested Link to comment Share on other sites More sharing options...
ManwithSupra Posted October 29, 2015 Author Share Posted October 29, 2015 (edited) Possible new Livery for next year I think it looks the nuts Should look nice when its done! Edited October 29, 2015 by ManwithSupra (see edit history) Link to comment Share on other sites More sharing options...
