Active spoiler removed - warning lights on dash
Branners
Had a Stillen front fitted so the active spoiler came off.
As expected theres now a warning light on the rev counter and the active spoiler light is flashing.
Did a search on how to fix this but couldnt see anything obvious. How do you stop the warning lights when you have removed the active spoiler, and where is the active spoiler ECU located?
thanks
  • 4 months later...
Just about to take the dash apart to get to this.
Just need some clarification on how to stop the warning triangle.
Just removing the active spoiler ECU isnt enough?
If so then I need to link pins 3 and 4 together on the active spoiler plug, is that the plug behind the bumper or the one behind the dash?
Its the plug behind the bumper, well thats what I did anyway and has been fine for 3 years now!!
I seem to remember thats all I did with mine but thats a while ago now.
No need to link any pins. I had the very same problem. I found out you need to press the "off" button from the switch (with the power on) and then remove the plugs from motor and ecu. That way you don´t get any errors and don´t need to link any pins
  • 2 weeks later...
