Things to change when doing the clutch
CanisLupus
Got myself an Exedy Twin Plate and i'm going to change from a Stock clutch setup. Going to get a set of flywheel bolts as well as the release bearing and the rear main seal.
What other parts should i change when i have the gearbox removed already? Thought about getting a TRD gearbox mount are they any good or are the vibrations that bad as sometimes described?
Might be worth changing all the clips and ring spacer that hold the thrust bearing in place. I changed all mine when I changed my clutch. Also changed spigot bearing in the centre of the fly wheel. It can be a pita to change without the tool though. Can be brought from Toyota for about £60. Also thrust bearing as you have mentioned and oil seals that have also been mentioned. I would defenitly change the gearbox oil for sure. One of the traders on here should be able to get hold of the proper V160 gear oil. I have a TRD gearbox mount and haven't really noticed anything diffrent from stock.
Edited by fastcar (see edit history)
Sounds good Chris.
Found some part numbers, are those parts sufficient for the clutch fitting itself or do i need anything else for an Exedy Twin Plate?
96152-00500 snap ring
90903-63001 t/o bearing
90560-50001 snap ring
90560-79001 spacer
90206-12006 wave washer
90520-75001 snap ring
31264-14060 spring
31231-14050 hub
90363-12002-77 pilot bearing
90910-02115 flywheel bolts
Would you replace all of those parts or just the snap rings and bearings as Toyota recommends?
