Guess the Part! (help required)
Elliot
First of all - bear with me!
When I got the car, the guy I bought it off handed me a bag of bits and explained what they were. I was hardly listening, as I was too busy worrying about not writing it off on the first corner!
I've taken a photo (below) and would appreciate if anyone can identify any of the bits, and what they go with.
I guess most of the cables are for the turbo timer, or gauge but what goes with what? Are there any bits missing? etc etc
I'll probably sell these once I know, but for now any help would be much appreciated!
I'll start!
A.
B.
C.
D.
E.
F.
G.
H. Blitz Dual Turbo Timer
I. Racing Meter AG Ex Temp
J.
K.
L.
M.
N.
O.
Good aren't I!
J and K look like Temp probes for the Gauge. E are also for the top Rad pipe. G looks like an Extrenal Wastegate and N and O look like something for your alarm.
A.
B.
C.
D. Jubilee Clips (for......?)
E. Bits for top radiator pipe (?)
F.
G. External Wastegate (?)
J. Temperature probe for gauge (?)
K. Temperature probe for gauge (?)
L.
M. Hard pipe kit for top water hose to rad (?)
N. Bracket for temp guage
O. Alarm leads (?)
G is an extra interchangeable head for a blitz supersound dump valve.(it is the quieter one)
A.
B.
C.
F.
G. Extra interchangeable head for a blitz supersound dump valve (?)
L.
O. Alarm leads (?)
Would this head be the quieter one as mine is bloody loud!? (sounds like a bus!) :)
'D' are the jubilee clips to clamp 'E' on to 'M'. And 'A' is, er, a pipe. :)
AHA! They fit! :) (why didn't I think of that!)
A.
B.
C.
D. Jubilee Clips to fix E onto M
F.
K. Temperature probe for gauge (?) Pressure sender for gauge (?)
L.
M. Hard pipe kit for top water hose to radiator (?) Uses 2 black 'bits' (E)
O. Alarm leads (?)
K (assuming that's the larger one next to J with green writing on it)- looks exactly same as my apexi oil pressure sender
I didn't realise when I took the photo, but J & K are the same, turned around at different ends.
Do you mean the curled up one? I meant that to be L
A.
B.
C.
F.
L.
O. Alarm leads (?)
A.
B.
C.
F. EGT Probe
J. Temperature probe for gauge (?) Pressure sender for gauge (?) o2 Sensor (?)
K. Temperature probe for gauge (?) Pressure sender for gauge (?) o2 Sensor (?)
L.
O. Alarm leads (?)
A is just a piece of silicone hose isnt it.
Need better pics of other bits.
D.
Yeah, I think it's just a spare bit out of the car. Haven't looked lately but think it goes into the FMIC or Rad.
Thought it might be used in conjunction with some of the other bits on there.
What other photos? I'll put some more on!
If the curled up one has the large sender with green on it then yes :D
Still sure L is oil pressure sender
A. Random/spare hose (for any of the other parts?)
B.
C.
F. EGT Probe
L. Oil Pressure Sender
O. Alarm leads (?)
