SupraP-Z Posted November 1, 2011 Share Posted November 1, 2011 Hey all, recently ive been hearing this high pitched annoying squeaking noise on the front passengers side wheel, it only happens when i turn the steering wheel slightly to the right though. Any ideas what it could be? Wheel bearing maybe? To top it up the brakes are quite squeaky too...new pads/discs on the cards? Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted November 9, 2011 Author Share Posted November 9, 2011 Anyone? Quote Link to comment Share on other sites More sharing options...
Tyson Posted November 10, 2011 Share Posted November 10, 2011 (edited) I'd check: 1.Disc warped 2.Disc thickness (lip) 3.Pad thickness 4.Caliper seals 5.Bearing (not too sure how) I'm betting its caliper seals (bearings tend to last a very long time) but its best to check the easy stuff first like discs and pads. Edited November 10, 2011 by Tyson (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted November 10, 2011 Author Share Posted November 10, 2011 Do you think thats whats causing it to squeak when i turn the wheel to the right though? the brakes are squeaky as it is....but this happens when im not braking at all, just cruising along, turn the steering wheel slightly to the right and i hear an awful high pitched squeak like theres a mouse stuck in the wheel somewhere lol Quote Link to comment Share on other sites More sharing options...
Tyson Posted November 10, 2011 Share Posted November 10, 2011 Do you think thats whats causing it to squeak when i turn the wheel to the right though? the brakes are squeaky as it is....but this happens when im not braking at all, just cruising along, turn the steering wheel slightly to the right and i hear an awful high pitched squeak like theres a mouse stuck in the wheel somewhere lol Could be some crap stuck between the disk and the pad. Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted November 10, 2011 Author Share Posted November 10, 2011 Hmm...ill have to jack it up and take a proper look, see what exactly is causing the noise. Thanks for your replies Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted March 3, 2012 Share Posted March 3, 2012 I seam to be getting this at the moment as well as the squeaking brakes, What turned out to be your problem in the end??? Edit: Back left seams the problem for me. Quote Link to comment Share on other sites More sharing options...
Benjy Posted March 3, 2012 Share Posted March 3, 2012 I get an annoying squeak from the passenger side, but only when the wife's in the car. Wierd.... Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted March 3, 2012 Share Posted March 3, 2012 I get an annoying squeak from the passenger side, but only when the wife's in the car. Wierd.... HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!! How do you solve that one?? Quote Link to comment Share on other sites More sharing options...
David P Posted March 3, 2012 Share Posted March 3, 2012 The brake pads are designed to 'squeak' when they need changing. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted March 3, 2012 Share Posted March 3, 2012 The brake pads are designed to 'squeak' when they need changing. Something on mine squeaks when driving?? Quote Link to comment Share on other sites More sharing options...
Bossco Posted March 3, 2012 Share Posted March 3, 2012 If you have Jap calipers then Im guesing the clip that holds the pad in place is rubbing on the disc. Quote Link to comment Share on other sites More sharing options...
Benjy Posted March 3, 2012 Share Posted March 3, 2012 HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!! How do you solve that one?? ?? Quote Link to comment Share on other sites More sharing options...
Benjy Posted March 3, 2012 Share Posted March 3, 2012 On a serious note, my grooved disc cracked and that made a squeaking noise Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted March 3, 2012 Share Posted March 3, 2012 On a serious note, my grooved disc cracked and that made a squeaking noise Yeah I am going to get them checked out next week to see what is what... Doubtfull it is anything too serious. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted March 18, 2012 Share Posted March 18, 2012 Well my rear left squeaking seamed to be exhaust related thank god and might be solved now which is a relief to my ears and street cred............ I have a NA so scrap the second part as I have no street cred...Like Abz Quote Link to comment Share on other sites More sharing options...
Batmax Posted August 17, 2012 Share Posted August 17, 2012 Hi Did you find what was the cause of the noise ? Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted August 17, 2012 Author Share Posted August 17, 2012 I havent actually no, its still there but a lot less now, only happens sometimes... i didnt even know people posted in this thread this year, completely forgot about it! Will update as soon as i do get it sorted...im pretty sure my bearings need changing nonetheless Quote Link to comment Share on other sites More sharing options...
