mellonman Posted November 1, 2011 Share Posted November 1, 2011 is a -8 an oil return line big enough for a dbb turbo? i know they have a restrictor on the feed and that the normal oil return is a - 10 and the return kit i have is -8 so was wanting to check before it gets fitted. Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 2, 2011 Author Share Posted November 2, 2011 sod it for the sake of a tenner i brought the 10an fitting Quote Link to comment Share on other sites More sharing options...
Scott Posted November 2, 2011 Share Posted November 2, 2011 I can't see 8AN being an issue with a dbb. As you say it has a restrictor so it won't be a high volume of oil wanting past. No harm in getting AN10 though. You will need 2 fittings I would have thought, one for the tubby and one for the block. Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 2, 2011 Author Share Posted November 2, 2011 i know just done about £80 on fittings just for the oil return line, there are so many little bits for a single conversion that get over looked when budgeting for! i would say all the little bits, breather system,catch can, oil and water lines, intercooler piping,filter + piping, heat wrap, turbo blanket, can easy make it up to £500 Quote Link to comment Share on other sites More sharing options...
Scott Posted November 2, 2011 Share Posted November 2, 2011 i know just done about £80 on fittings just for the oil return line, there are so many little bits for a single conversion that get over looked when budgeting for! i would say all the little bits, breather system,catch can, oil and water lines, intercooler piping,filter + piping, heat wrap, turbo blanket, can easy make it up to £500 It will blitz way past £500 IMO. For my breather system I'm simply running to -10AN into a -10 to -12an Y connection and then -12an to the rear of the car. That alone is going to work out around £200 lol. It's insane. I'm just over what I budgeted for at the moment and I still have a couple of odds and sods to buy. £10103 I'm at including the clutch that I'm still to buy and the ECU that I am in the process of buying. By the time all is said and done I'm hoping for just over 11k. Quote Link to comment Share on other sites More sharing options...
johnny g Posted November 2, 2011 Share Posted November 2, 2011 It will blitz way past £500 IMO. For my breather system I'm simply running to -10AN into a -10 to -12an Y connection and then -12an to the rear of the car. That alone is going to work out around £200 lol. It's insane. I'm just over what I budgeted for at the moment and I still have a couple of odds and sods to buy. £10103 I'm at including the clutch that I'm still to buy and the ECU that I am in the process of buying. By the time all is said and done I'm hoping for just over 11k. Indeed. On my build, I think it was around £700 just on fittings, hoses, clamps, wrap, etc etc Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 2, 2011 Author Share Posted November 2, 2011 alot of mine was done when i went hybrid, so not getting hit so much now but its these odd £20 here £30 there, still cant wait should have all the bits by next week and i have a week off for my birthday and what a present it will be for myself a single turbo supra NICE! Quote Link to comment Share on other sites More sharing options...
