Wishbone & Arm Bushing - A fresh perspective
Scott
Do you have a note of the number at all mate? Where did you get it from?
Soarer front lower arm:
rear bush.. 48655 - 24050
front bush.. 48651 - 24040
http://www.ebay.co.uk/itm/380359401788
All 4 bushes, no more for sale here though, I've just fitted the rear bushes.
What a job removing the wishbone, the rear bolt was rusted solid. :blink:
You cannot see the full depth of the void in the pic of the rear bush, it goes down further into the bush against the outer sleeve. Much stiffer after filling this up with the polyurethane, I used shore hardness A - 60.
Edited by merckx (see edit history)
Once upon a time you couldn't buy replacement bushes for the Soarer, then an Aussie called Andrew Vlamos (VFT Bushes) had them manufactured (plenty of stuff on Planet Soarer about these). I don't know if VFT are still trading.
Some time later, "official" Toyota bushes became available... allegedly supplied by VFT. :)
Later still, Branz bushes arrived - http://soarerparts.com/products.asp?cat=7 (ignore anything marked "UZZ32", that's the V8 with active suspension)..
Edited by garethr (see edit history)
  • 3 weeks later...
Hi Guys..
I have been doing some research on this, thought I would put up the results..
TRD list all the front arm bushes, they still keep stock.
For the Rear they only list the one for the Lower Arm No 1.
Addtionally, I managed to find the part numbers for all the OEM bushes.
I checked at my local dealer here in Japan, they dont list them at all, you have to buy the entire arm.
So I guess back to square 1 on this..
I had the front TRD bushes fitted on my Supra many years ago, but as said most are now discontinued. If you're fitting them yourself it would work out cheaper but if you're paying someone to fit them any saving would probably be cancelled out by the extra labour costs involved. If I was doing it now I'd fit new OEM arms.
They are still available from TRD Nic, I just checked last week.. But they only work out slightly cheaper than new arms..
I will have a full set of Suspension arms up for sale soon if your intrested,
All the bushes were replaced with R2 racing ones and only covered around 6k miles on them since they were installed.
Are they poly bushes mate?
Edit - Just read about them on the MVP site..
Did they improve the handling and ride as claimed?
Edited by Samurai 20V (see edit history)
