xxl225 Posted October 31, 2011 Share Posted October 31, 2011 (edited) any info on the best place and if its the main dealer anyone have any part numbers? thanks in advance Edited November 1, 2011 by xxl225 (see edit history) Link to comment Share on other sites More sharing options...
Brazil Posted October 31, 2011 Share Posted October 31, 2011 Paul Whifbitz buddy...! Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 1, 2011 Share Posted November 1, 2011 All the same as none VVTi, bearings are selectively sized. Link to comment Share on other sites More sharing options...
xxl225 Posted November 1, 2011 Author Share Posted November 1, 2011 big thankyou chris is it the same as rb26 graded mains etc the engine has no damage just doing it while its on the stand thanks Link to comment Share on other sites More sharing options...
Scott Posted November 1, 2011 Share Posted November 1, 2011 Not as well going aftermarket? Link to comment Share on other sites More sharing options...
xxl225 Posted November 1, 2011 Author Share Posted November 1, 2011 oh also i'm looking for the arp studs for the standard rods anyone got them in the uk? Link to comment Share on other sites More sharing options...
xxl225 Posted November 1, 2011 Author Share Posted November 1, 2011 Not as well going aftermarket? do you mean bearings or rods and pistons Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 1, 2011 Share Posted November 1, 2011 Yes, just like Nissan, grades are on crank and block. I think http://www.coordsport.com will have the ARP bolts. Link to comment Share on other sites More sharing options...
Scott Posted November 1, 2011 Share Posted November 1, 2011 do you mean bearings or rods and pistons The bearings in particular. There is so little difference between OEM and aftermarket that I would personally go aftermarket with a known decent brand. Gives headroom for any future mods too. Changing the bearings and the rod bolts are taking out the well known weak areas of the stock block Piston rings would be next on the list for me. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 1, 2011 Share Posted November 1, 2011 (edited) With the OE bearings, if you have access to proper measuring gear, you can get the clearances to your liking or Toyota' recommendations, with aftermarket most are one size fits all. With a good used crank a quick polish and sizing means you can spec a slightly O/size bearing from Toyota to get clearances tighter than an aftermarket bearing may be able to achieve. There's a lot to be said to sticking OE with sized bearings if you want clearances spot on. The best piston rings in the world are considered those from Japan, most US ones are dire, in sizing, tolerances and sometimes material. They certainly need hand gapping, and that's something which is definitely a bit of an art form without a ring grinder. Edited November 1, 2011 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
Scott Posted November 1, 2011 Share Posted November 1, 2011 With the OE bearings, if you have access to proper measuring gear, you can get the clearances to your liking or Toyota' recommendations, with aftermarket most are one size fits all. With a good used crank a quick polish and sizing means you can spec a slightly O/size bearing from Toyota to get clearances tighter than an aftermarket bearing may be able to achieve. There's a lot to be said to sticking OE with sized bearings if you want clearances spot on. The best piston rings in the world are considered those from Japan, most US ones are dire, in sizing, tolerances and sometimes material. They certainly need hand gapping, and that's something which is definitely a bit of an art form without a ring grinder. I was looking into this a couple of weeks ago. The PE bearings are 6 sizes and are said to be the best available. I would just go with stock rings, but I would still replace them if I was in there Link to comment Share on other sites More sharing options...
xxl225 Posted November 1, 2011 Author Share Posted November 1, 2011 again thanks chris i'll give paul a shout same as acl on rb26 made with a one size to fit all which is why you see so many rb26 with bearing failure after rebuilds i'll stick with the oem stuff i think Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 1, 2011 Share Posted November 1, 2011 If it were my own engine I would. My RB26DETT is on stock bearings, as is my Toyota 4A-GE turbo engine. Link to comment Share on other sites More sharing options...
