neilp9876 Posted October 31, 2011 Share Posted October 31, 2011 Whilst doing a trackday last weekend I got a massive cloud of smoke coming from the car. At first I thought I had killed it but it still runs perfectly. The smoke is coming from oil burning off the exhaust, underneath the drivers seat area so quite far back under the car. Its an autobox and it looked to be in that area. There are no obvious leaks and no large pools of oil or fluids although there are traces around the underneath. Never happens under normal / fast driving. Only occurred when braking as hard as possible from high speeds, i.e the ABS is on full chat (17" toyo tyres in the dry). Are there any breather pipes / over flows or anything around the autobox area? Anything else that could leak under braking from the engine? I would expet leaks to come from the front but for it to be so far back I am suspicious about the autobox? Any ideas, anyone. Link to comment Share on other sites More sharing options...
Swampy442 Posted October 31, 2011 Share Posted October 31, 2011 On top of the box theres a pressure relief valve, was your fluid level on the high side? Link to comment Share on other sites More sharing options...
neilp9876 Posted October 31, 2011 Author Share Posted October 31, 2011 Yes it was on the high side. I have just had a couple of coolers fitted so it had all been topped up to the top. Any idea how much pressure is needed to open the valve? Link to comment Share on other sites More sharing options...
Swampy442 Posted October 31, 2011 Share Posted October 31, 2011 Couldnt tell you mate, Ive experienced the same thing myself on my old auto. All Id say is get the car on a flat surface, engine running and re establish the gearbox level Link to comment Share on other sites More sharing options...
neilp9876 Posted October 31, 2011 Author Share Posted October 31, 2011 Brilliant, thanks for the that. I feel a bit better that its nothing more serious. Cheers Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 3, 2011 Share Posted November 3, 2011 It sounds like you have overfilled the auto box, this is really BAD when you use it on a track as the oil will foam, (and overflow, as you have found out) You do realize that you check auto box fluids afyer going through all the gear positions (stationary is fine) them. leaving the engine idling, you dip and check the oil level. If you check it when the engine is not running you will not get anything like a correct level reading. I would drain it to the correct level ASAP, and certainly before it is driven hard. There is no pressure valve, it's just a vent. Link to comment Share on other sites More sharing options...
neilp9876 Posted November 3, 2011 Author Share Posted November 3, 2011 Do you think the fluid should be flushed and replaced or will it be ok? Its already been thrashed now. Link to comment Share on other sites More sharing options...
Havard Posted November 3, 2011 Share Posted November 3, 2011 It sounds like you have overfilled the auto box, this is really BAD when you use it on a track as the oil will foam, (and overflow, as you have found out) You do realize that you check auto box fluids afyer going through all the gear positions (stationary is fine) them. leaving the engine idling, you dip and check the oil level. If you check it when the engine is not running you will not get anything like a correct level reading. I would drain it to the correct level ASAP, and certainly before it is driven hard. There is no pressure valve, it's just a vent. Good info Chris. I had wondered why my level was high after the car had been stood still for 6 weeks. The last time I checked the level, the car was idling. This time I checked all levels before I fired her up last Saturday. H. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 3, 2011 Share Posted November 3, 2011 The fluid should be fine so long as it does not smell at all burnt, nor look darkly discoloured. It's too dear to waste Link to comment Share on other sites More sharing options...
wile e coyote Posted November 4, 2011 Share Posted November 4, 2011 As chris said with engine running put gear lever into every gear (i usualy go back and forward a couple times in gears) then check level with it still running in neutral and on level ground of course. Link to comment Share on other sites More sharing options...
