mark newman Posted October 30, 2011 Share Posted October 30, 2011 pic's needed of twin 044 pump set up. in tank thanks Mark Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 30, 2011 Share Posted October 30, 2011 Quote Link to comment Share on other sites More sharing options...
mark newman Posted October 30, 2011 Author Share Posted October 30, 2011 Thanks for that is it a standard tt hanger Jamie . did you get the problem sorted in the end , and would you do this set up again or use differnt pumps. Has this set up, use a large y piece to join into one fuel line. any help on this would be good. Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 30, 2011 Share Posted October 30, 2011 (edited) Yes stock hanger, never had any problems with this setup, I dont see the point in doing it any other way, them big external pumps like kdw runs would drive me insane, the noise from them is horrendous, twin 044's you cant even hear and they deliver the goods. Wire a fuel pressure sensor into the syvecs, any drop in pressure (if one pump was to fail) and the syvecs will switch the car off, also stage them so only one pump runs for when you are off boost, syvecs also controls this. Edited October 30, 2011 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
mark newman Posted October 30, 2011 Author Share Posted October 30, 2011 Thanks for that Jamie I will get building it then Ryan can sort out all the hard bits . Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted October 30, 2011 Share Posted October 30, 2011 Mark would you post up your build on this? Looking to do the same in my car and a guide would be great. Especially the fuel line connectors on the top. Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 21, 2012 Author Share Posted January 21, 2012 http://i30.photobucket.com/albums/c338/jamie450x/5022093c.jpg Looks good Quote Link to comment Share on other sites More sharing options...
