p3te Posted October 30, 2011 Share Posted October 30, 2011 (edited) My water temp Gauge, it’s a HKS Electronic Gauge it use to work fine but now the needle doesn’t want to move to display the temp, I’ve replaced the temp sensor in the engine bay and the buttons work fine on the gauge, you can even hold the button to test the needle and it sweeps around fine but the needle is just sat on the bottom and doesn’t move no matter how hot the water temp what could the problem be? is it Knackered? Edited November 3, 2011 by p3te (see edit history) Quote Link to comment Share on other sites More sharing options...
p3te Posted November 3, 2011 Author Share Posted November 3, 2011 anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 4, 2011 Share Posted November 4, 2011 hi mate im not sure about the hks gauges but i just installed a warter temp on my mates integra and i couldnt get it to read the warter temp but everything else was working fine just like yours. after 2hrs of scratching my head i found out that the senseor its self has to be earthed! if you need me to explain better you can call me on 07544904547 altho this might not be the case for you. but its worth a shot ;-) Quote Link to comment Share on other sites More sharing options...
p3te Posted November 4, 2011 Author Share Posted November 4, 2011 hi mate im not sure about the hks gauges but i just installed a warter temp on my mates integra and i couldnt get it to read the warter temp but everything else was working fine just like yours. after 2hrs of scratching my head i found out that the senseor its self has to be earthed! if you need me to explain better you can call me on 07544904547 altho this might not be the case for you. but its worth a shot ;-)hi, the new sensor ive just fitted has 2 wires (like the hks one) black and white is one of these not the earth? ive tried changing the wires around but still get no joy Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 4, 2011 Share Posted November 4, 2011 hi, the new sensor ive just fitted has 2 wires (like the hks one) black and white is one of these not the earth? ive tried changing the wires around but still get no joy im not 100% sure with the hks sensors mate but the one i fitted had wires coming from it with a plug on the end. but for some reason it had to be earthed separate. i only found out by ringing the company who sold it to us outher wise i would of never worked it out as it didnt say on the instrutions. can you not find any instrutions on it? if you post up the model number i will look into it for you ;-) Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 4, 2011 Share Posted November 4, 2011 ps: check that the signal wire hasnt broke away near to the gauge. trace all wires back to make sure there is no damage to any of the wires Quote Link to comment Share on other sites More sharing options...
p3te Posted November 4, 2011 Author Share Posted November 4, 2011 its bugging me as it was working fine not long ago, it stopped and when ive checked the sensor the wires were nearly snapped so i replaced the sensor and its still not reading a temp Quote Link to comment Share on other sites More sharing options...
p3te Posted November 4, 2011 Author Share Posted November 4, 2011 i also tried to find a wiring diagram for it a few weeks back to check its wired up the way its supposed to be but never found one Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 4, 2011 Share Posted November 4, 2011 i notice you have geordie above your advatar! i live in gateshead so if you cant work it out you can pop it over and we can have a quick look. as 2 heads are better than one lol but if you cant find any brakes in the wires anywhere it could be done for! but im sure it will just be somthing simple lol it always is lol did you buy a new hks sensor or a copy? ( thats if you can buy a copy lol)? Quote Link to comment Share on other sites More sharing options...
Scott Posted November 4, 2011 Share Posted November 4, 2011 Sounds like the wire is broke further up the line towards the gauge, as already suggested. The fact that the needle is sweeping would suggest this. Are they bulb sensors or thermocouples? Quote Link to comment Share on other sites More sharing options...
p3te Posted November 4, 2011 Author Share Posted November 4, 2011 i notice you have geordie above your advatar! i live in gateshead so if you cant work it out you can pop it over and we can have a quick look. as 2 heads are better than one lol but if you cant find any brakes in the wires anywhere it could be done for! but im sure it will just be somthing simple lol it always is lol did you buy a new hks sensor or a copy? ( thats if you can buy a copy lol)?it just a universal fit sensor i bought, i think ill have one last check at everything this wkend, i feel like replacing all of my gauges for some blue backlit ones lol Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 4, 2011 Share Posted November 4, 2011 If you can't find any brakes. The first thing I would do is by a genuine HKS sensor as I'm sure that will sort out the problem. I know it's a different thing but I bought 2 bosh universal single wire lambda sensors to replace my old oem sensors and my car would not run rite it was spluttering all over the place. So I now would not buy universal and copy's lol. I know some copy's are ok but it will reduce any problems not going this route ;-) Quote Link to comment Share on other sites More sharing options...
hodge Posted November 4, 2011 Share Posted November 4, 2011 Remove the signal wire from the back if the gauge and unplug the sensor. Check the resistance from 1 end of each wire to the other. If the resistance is fine I'd get a genuine HKS sensor and try that. Quote Link to comment Share on other sites More sharing options...
