single turbo vacuum nipple
mellonman
hi guys i have my single turbo kit now and in the process of getting all the final little bits sorted, so i was looking for my vacuum point for the wastegate and has been said its best to take it from the compressor housing which my housing is already drilled and tapped so i was after where i can i get the vacuum nipple from?
You can get the fitting from EBay for pennies dude. The thread in the compressor housing will be 1/8 NPT if your just fitting silicon hose just get a push on adaptor to 1/8 NPT. I think the push on will be around 7mm. If your using proper fittings like mine you can use either -3AN or -4AN.
Hope this helps.
