Any CNC machinists on here
Al Massey
I have a GT style wing and i want the legs to be higher
So i'd like something made up to do the job
Cheers for the inputs guys
Can you manage a sketch to show what you want with dimensions and take a pic of the
legs on your wing and post them up.
How much higher are you looking to raise it ?
I've had a quick look and i'd have thought an easier cheaper way of raising the
wing would be to make new legs or a piece to fit between the feet and exsisting legs
Making new feet would be the hardest route in my opinion. The APR ones look like
their a casting
It's a custom built one
It has the apr gt feet that uses the stock holes
It's just the feet that I need to be bigger
It's the legs I need making up the feet are fine
Ill take a pic later and show you what id like
:innocent: :)
No problem :)
If you find someone local with a laser or water jet cutter just get them cut from some hard alloy plate.
Can you laser alloy? I know we never did any in work, assumed it couldn't be done. Same with titanium but that's obvious why lol.
My local laser cutting emporium (DC Developments near Norwich) can handle ally up to 6mm thick and program direct from a DXF file without any dimensions.
I've used them several times for simple jobs. Far easier than cutting by hand if you can wait a week or so.
