Blitz rad cap question.
tony tt
Running a 1.3 bar cap with an original (old) heater matrix is asking for trouble. NEVER run a higher pressure cap than needed, the only real need is on race cooling systems where you need a safety margin if you run hot in a race, and you want to stop the system boiling out coolant. There's probably no one here who should actually be running higher than stock pressure caps, it's just asking for a tired matrix or core plug to fail.
