heat sleeve
Rob_Mitchell
Not that pricey if it stops wires melting ect. thats the stuff i was looking at scott. im just sure i read somewhere that it can come in sheet style.
Are you looking for something different from sleeving or do you plan on stitching it yourself?
no im just sure i have seen the same stuff on a self adhesive roll or sheet. so you just cut how much you need and roll it over the wires ect.
I hate seeing something and not finding it again.... AAHHHH
Yeah, that's the stuff I just linked to.
You arent looking for a "sleeve" then though are you ;)
I would go for the tubular/ sleeve stuff, it will last much longer than any sort of adhesive wrap, plus if you need another wire in the sleeve you can just slide it through, solder/ crimp on some connectors, et voila, rather than having to unwrap it all again an throw away the old wrap. Plus I have always thought a solid sleeve looks better and is easier to clean :). What exactly are you hopeing to protect with this stuff? Just wires or other things too?
