Searching for any part number?
merckx
Why does the search on here not locate a full part number in the usual format, it used to work?
For example, 58261-14010 with no spaces.
You have to put a space on either side of " - " for it to work. Not difficult to do if you're aware of this but most won't be.
It probably follows the search standard now, so that if you put a minus sign in then it tells the search to ignore anything with the text after the minus.
So it searches for 58261, but if it has 14010 in it then dont display it.
Standard search syntax so not sure it can be changed easily.
