Bad idle without throttle response
mrmyagiii
Sometimes my jspec tt auto starts acting really weird. When driving normally there is no problem at at but when i slow down to like 10mph the revs go up and down like mad en even sometimes stalls. Last night this happened on startup and when i pressed the throttle revs didnt go up, engine made a clunky sound. Had this problem before but its not always happening. I recently changed all coil pack connectors except 1 wich looked fine, and all spark plugs. Anyone that can point me in the direction of where i should look at?
Today on startup it instantly stalled then after a 2nd startup i had to push the throttle down alot of times to even get the slightest response. This only happens on startup, low speed driving or occasionally on "cruising speed" (60mph) but only when the road gets bumpy. Hopefully someone can help me with this problem because its getting really annoying when i startup my car at work and i need to explain to my friends why the best looking car of town is acting this worthless.
The car here is running quite well, it has issues, but not anything that will help you. Have you got access to a wideband O2 sensor and readout, and a decent multimeter? I would start at checking the MAP sensor and the fuel pressure regulator both have perfect hosework to them, no leaks, no T offs to strange none stock add ons that maybe causing issues.
