Hmmm What Going on hear then . . . .
jast
Question Time - AGAIN!
Seems when driving the supe, kaining it from say 60 onwards it seems to go like the stink and then sort of hang back as if its got no power, then its off again, then it stops, and goes etc??? Really weird, anyones supe does this?????
Help Please
1: If the big red triangle and engine warning light appear along with a large jolt then it's likely to be fuel cut.
2: If it's a progressive slowing down, stuttering then it's likely to be plugs.
Fit NEW and go one grade colder.
3:If it just won't go past 112mph then you have the top speed limiter still and need to remove it.
Email me on [email protected] for 1 and 3 resolutions.
2: can be sourced from JPS Motorsport, Torque IC, TDi or yourself directly from a motor fator.
You need NGK 6097 (BKR7E) for example.
Regards
Pete
That's exactly what I had last year, I thought it was a 'soft cut' at about 16PSI. After much discussion I got BKR7E's put in to replace the stock platinum 6's and I now hit the 18PSI 'hard cut' red triangle on 'good' days.
