battery harness
redsupraman82
guys, i know this may seem a silly question but can i check something..... the battery engine harness runs from the started motor to fuse box to earth on the block the to battery? is there no earth that goes to the body?:rolleyes:
there is an earth that goes from that battery (-ve) to the body, and nothing would work on the car!
Guest Rsand85
would cause major issues with fuel pump,spark,engine management!I know this as i learned the hard way a short time ago[OOPS][/OOPS]
what happend exactly?? at the moment i have just completed a N/A to TT transplant but not getting any juice from the fuel pump. however when i force fuel into the engine there is still no firing up?? could this be causing it??
Guest Rsand85
yup that sounds same as my prob had no juice or spark is your engine management light coming on when you first turn the ignition on?
Guest Rsand85
yup i had no management light either!It was the main that earth bolts on right next to the battery unbolt it give it a rub with sandpaper and the chassis to and try then
