Notts_TT Posted October 22, 2011 Share Posted October 22, 2011 Does a stock tt spec supra run an internal or external wastegate.... Just so I know which diagram to follow for bc fitting... I've had so much info on fitting the AEM one but still confused Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted October 22, 2011 Share Posted October 22, 2011 A stock tt has an internal wastegate. Rich. Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted October 23, 2011 Author Share Posted October 23, 2011 Does the boost controller use the top wastegate pipe to turbo or the side wastegate pipe to the turbo.. The fitting pic shows the solenoid sits between the turbo and one of pipes on solenoid... Thanks Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 23, 2011 Share Posted October 23, 2011 Both pipes on the front turbo wastegate capsule go to the same half of the chamber, so use either. Quote Link to comment Share on other sites More sharing options...
