Free HDTV packages
Blackie
Not really sure what you are after bud. Are you looking for an HDTV freeview or do you mean a package from virgin/sky/bt?
Modern TVs have HD freeview tuners built in nowadays, I'm guessing you don't want a new tv though?
You have the option of buying a freeview HD tuner/recorder if you want though. The prices vary depending on what you are after...
Standalone Freeview HD set-top box
Standalone Freeview HD Set-Top box with Recording
Those are the cheapest I can find on the Argos site. The world is your oyster though :)
Cheers. Its a st top hd box with no monthly subsription with th capability of rcording im after but one that only needs an aerial and not a dish. The tv we have has HD built in but i think we still need to get the box to get the hd (?)
If it has Freeview HD then you are sorted, if not you need the set-top box. You will know by the channel listings that you have on your TV. If the HD channels are there and they work then you have freeview HD. It's a relatively recent thing though so the TV would need to be a couple of months old at most.
No its two years old min. Its "1080 Hd ready" but thats as far as it goes. will need to get a set top box then
Thats what i thought, Its the top mark isent it? Lower is 720p
It depends what letter you have at the end of the figure. "i" means interlaced, which is basically half the picture it says it is and "p" is progressive which is classed as "full".
You have, in the following order...
1080i - 720p - 1080p
Any of the above are classed as HD Ready but only the 1080p is classed as "Full HD". You won't notice a difference between 720p and 1080p without getting seriously big in the screen size.
