Noz Posted October 20, 2011 Share Posted October 20, 2011 Hi guys, thinking about trying to make some biofuel for my focus. I was considering getting a Straight-Veg-Oil kit to heat the oil before it enters the engine so it wouldnt need mucking about with, but the cost of veg oil from the shop isn't much lower than actual fuel, so I'll have to source it as waste and filter it. If im going to have to filter it, I might as well treat it through a biofuel system at the same time and save having to buy a kit, get it fitted, have 2 tanks in my car and be able to use it for another car. Any experiences with this, or any recommended suppliers of biofuel kits or from waste veg oil. Opinions, experiences and recommendations welcome Quote Link to comment Share on other sites More sharing options...
ScottC Posted October 20, 2011 Share Posted October 20, 2011 Am I right in thinking you will still need to pay duty? Quote Link to comment Share on other sites More sharing options...
Noz Posted October 20, 2011 Author Share Posted October 20, 2011 only on over the legal limit, think its like 4.5k litres. Quote Link to comment Share on other sites More sharing options...
Supranature Posted October 20, 2011 Share Posted October 20, 2011 Some well researched and documented stuff on here http://www.pocuk.com/forums/viewforum.php?f=77&sid=7d08047ca48a6f55853307c232e4d5c0 Quote Link to comment Share on other sites More sharing options...
Noz Posted October 20, 2011 Author Share Posted October 20, 2011 thanks Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 20, 2011 Share Posted October 20, 2011 Find out where your local takeaway gets there oil from as it will be cheaper getting it from a wholesaler rather than a super market. Quote Link to comment Share on other sites More sharing options...
absz Posted October 20, 2011 Share Posted October 20, 2011 Most modern diesel engines run on VERY fine tolerances on fuel injectors and high pressure pumps by using poor quality fuel you risk the service life of these items. i have seen damaged injectors due to veg oil and even bio deisel. prices for new injectors on modern cars are not cheap. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 20, 2011 Share Posted October 20, 2011 Modern common rail diesels aint fans of chip oil. If you get an old citroen/Peugeot with the Bosch pump you can bang as much chip oil through it as you want. Google it and see if your car is compatible first Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 20, 2011 Share Posted October 20, 2011 I used it in the saxo diesel before I killed it Quote Link to comment Share on other sites More sharing options...
Noz Posted October 20, 2011 Author Share Posted October 20, 2011 Duue to veg oil? Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 20, 2011 Share Posted October 20, 2011 Duue to veg oil? Due to attempting to cross breed it with a land rover, it didn't go well Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted October 21, 2011 Share Posted October 21, 2011 Due to attempting to cross breed it with a land rover, it didn't go well Lol! Quote Link to comment Share on other sites More sharing options...
Noz Posted October 21, 2011 Author Share Posted October 21, 2011 Most modern diesel engines run on VERY fine tolerances on fuel injectors and high pressure pumps by using poor quality fuel you risk the service life of these items. i have seen damaged injectors due to veg oil and even bio deisel. prices for new injectors on modern cars are not cheap. if biodiesel is made to the euro standards you are able to sell it legally to run in any motor as reliable as diesel, some supermakrets have biofuel as an option as if it goes through the correct process it has the same combustion properties and your engine won't be damaged by it, injectors will flow it no problem due to viscosity being the same. Quote Link to comment Share on other sites More sharing options...
