leakdown test would this work? and understanding
mellonman
i was looking up whta was involved with a leakdown test and come acrross this http://www.max-boost.co.uk/max-boost/Leakdown_tester.htm
im not 100% sure how you would read the leak on that?could anyone with the know please tell me.
is the leak down done as back up if you had a bad compression reading as they are so closly related
ie if you had bad compression say -20% you will have a bad leak down test -20%. and if you had good compression you will have good leak down test.
could you get good compression and bad leak down results?
