Evacuating air con refrigerant?
carlmhtt
You take the cap off the Schraedar valve and depress the pip. I would do it outside. Or just slowly crack a union. We have had a lovely September and October thanks to greenhouse gasses, go for it with a clear conscience :)
Just plant a couple of trees in your garden when your finished :)
just vent to atmoss :D
if you care for the enviroment that much jsut dont use the car once, go for a walk so you feel like youve balanced things out :)
jsut press the valve in and it squirts out like a deoderant can :)
(dont breathe it in tho)
when you come to remove the front ran there will probably be some left in there so be alert when it makes a loud noise as you seperate tthe hard pipes which go to the aircon rad
