Guest Rsand85 Posted October 14, 2011 Share Posted October 14, 2011 anybody fitted a water temp sensor to a na car if so where did you put it?cant find much info about it anywhere cheers Quote Link to comment Share on other sites More sharing options...
Bossco Posted October 15, 2011 Share Posted October 15, 2011 You can fit it in the top rad pipe. You would need to buy one of these to bridge the gap: http://www.google.co.uk/imgres?imgurl=http://www.autometer.com/img/products/2283_d.jpg&imgrefurl=http://www.supraforums.com/forum/showthread.php%3F534093-Installing-Water-Temp-Gauge.-Need-some-Help!&usg=__gPau7gYdwziZdv7YjdJgQcxGMM4=&h=300&w=300&sz=18&hl=en&start=12&zoom=1&tbnid=EwHa85NanrLFGM:&tbnh=116&tbnw=116&ei=TXSZTrf9JpGo8AOKotHWBQ&prev=/search%3Fq%3Dsupra%2Bradiator%2Bpipe%2Badaptor%26um%3D1%26hl%3Den%26sa%3DN%26tbm%3Disch&um=1&itbs=1 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 15, 2011 Share Posted October 15, 2011 Or do you mean where the stock sensor lives? Temp indication or ECU sensor? Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted October 15, 2011 Share Posted October 15, 2011 i have an adapter like the one above would rather take the temp from the engine itself tho prob just put a T-piece in to run both sensors was just a mater of interest as surely placing a temp sensor in the rad line wouldn't give the best reading for example if the thermostat seized a sensor in the rad hose wouldn't tell you what the water in the engine was doing?correct me if im wrong just trying to find the best place for it Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 15, 2011 Share Posted October 15, 2011 Have you no concept of punctuation or capital letters? Whats wrong with the stock position? Tap into the ECU temp sensor Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted October 16, 2011 Share Posted October 16, 2011 no i do not!and where is the ecu temp sensor?cheers Quote Link to comment Share on other sites More sharing options...
