vukelic Posted October 12, 2011 Share Posted October 12, 2011 So, some of you may remember that my belt tensioner went and i fixed that. Now, right after, the car has begun making a high pitched squeal. Very similar to a bird chirping, coming from under the hood. I took my belt off and there was no sound. Then i spun each pulley and found that the water pump/fan is the one making a slight squeak, I'm assuming when its spinning, that the light squeak turns into a loud chirp. I then held the fan still and spun the water pump and found it is making the noise. So my question is, what's the best way to fix this? 1994 mkiv na supra. Thanks Vukelic. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 13, 2011 Share Posted October 13, 2011 Simple, change the water pump, sounds like the bearing is buggered. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted October 13, 2011 Share Posted October 13, 2011 Simple, change the water pump, sounds like the bearing is buggered. plus 1 Quote Link to comment Share on other sites More sharing options...
vukelic Posted October 14, 2011 Author Share Posted October 14, 2011 thanks! Quote Link to comment Share on other sites More sharing options...
