Excel help - cell referencing
tbourner
Is it possible to use the information in a cell as the reference to another cell? I'm guessing not but hoped there might be a workaround that didn't involve VB coding!
Basically if I have say the number '5' in cell A1, can I then put a formula in cell B1 that points to a table of information and drags out the data in row 5 of that table?
Not really, it's got lots of company confidential stuff on it! Would have to rejig it first. I think I've cracked it now anyway.
It's 2 worksheets, sheet1 has a table of info from A5 down to AM106, sheet2 I want an input table from A1 to A10 where you can designate a row number, and it will source the data from sheet1 on that row (in column W in my case) and show it to you, so anyone can go in and fill in the ten slots with random row numbers and it will tell them the data from column W in all those rows (on sheet1).
The formula I've now got is:
=INDIRECT("'sheet1'!"&ADDRESS($A1,23))
Seems to work, I had to concatenate with the ampersand to get it to look at sheet1 as well as using the 'ADDRESS' function, so even more confusing!
It's fairly easy to do. You can actually get excel to write it for you by just clicking the cell you want to have the reference in, type in "=" and then click the cell you want to reference. I don't think it matters if it's a seperate sheet or workbook, it puts in the address for you. I had a sheet that did exactly what you are saying a few years ago.
OK I'm confused, surely that just shows the data in whichever cell you click on after the "="? It would be easier to just find the cell and look at the data wouldn't it? I want the referenced cell to change depending on an input from a completely separate cell.
It shows the current data, it updates everytime the sheet is opened or the sheet is refreshed (can be refreshed auto or manual).
Try it for a test, open up 2 seperate workbooks. Reference one to the other, save & close the one that has the formula, edit the original, save it, close it then open the one with the formula. It will now have the updated information.
Works fine for me anyway. Might not be doing exactly what you are after but I would give it a try to see if it's what you need.
