1994 J-Spec Toyota Supra Twin Turbo Auto For sale **ADVERT ENDED**
ManwithSupra
1994 J-Spec Toyota Supra Twin Turbo Auto For sale. Advert ENDED
Here is the list of what I have done/bought her over the 6 1/2 years of ownership.
• Tein Superstreet Coilover Suspension (only done a max of 6k miles on these – Installed on car brand new)
• Titan Front and Rear Adjustable ARB's (New Drop links and Hardware was installed at the same time)
• R2 Racing Front and Rear Suspension Arm Bushes (Ball joints inspected and are good condition when bushes installed)
• Front Ksport Big brake kit, 8pot calipers, 356mm discs (
• Rear Ksport Big brake kit, 4pot calipers, 356mm discs (
• Front and Rear Goodridge Braided Brake lines, with Motul 5.1 fluid (Installed at the same time as big brake kits)
• Front and Rear EBC Yellowstuff Pads (
• **ORIGINAL** 19" AXIS Hiro Alloy Wheels, these wheels are now very rare and IMO one of the best looking for a Supra.
• **FULL** Brand new set (
• Anti-Theft Richbrook Stainless steel Valve caps
• K&N Panel filter In stock Air box (best setup)
• Whifbitz Twin Box Exhaust system (96db) Only been installed on the car 4 months!
• Whifbitz 1st and 2nd Decat (1st cat will come with the car)
• Chris Wilson 1bar Restrictor ring
• AEM AFR Gauge (with Sensor installed onto 1st Decat pipe)
• Turbosmart Fuel cut defender
• Fields Harness (FCD is attached to this – saves cutting up the car loom)
• New Walbro fuel pump (
• NGK Iridium spark Plugs (
SMIC Intercooler Hard pipe kit
• Radiator Hose Hard pipe Kit
• Dry Carbon Radiator/FMIC Cover (Aesthetics as I don’t have a FMIC)
• S2000 Stubby Arial conversion
• Aluminium Polished relocated Radiator Overflow Tank
• Carbon Fibre Spark plug cover with custom TRD Decals
• Blitz Racing Boost Gauge mounted on Steering column
• Visual performance Electroluminescent cluster Dial kit
• Carbing Front Strut brace with Master Cylinder Stopper
• 4300k HID Main Beam headlamp conversion
• 4300k White LED sidelights and White LED rear number plate illumination
• Black Zunsport Front Grills (Side ports and Main Centre)
• Facelift front indicators and Clear side repeaters
• Facelift Rear lights with Internal Fog lamp conversion
• Black Supra Pure Sport Mats (great condition no wear)
• Driver (XL) and Passenger (Standard) Corbeau Pro Series Seats with Corbeau Fixed Side mounts (No Wear!)
• K&W Fixed Rail kit (can be manually adjusted to suit)
• Momo Nero Steering Wheel with Steering Boss
• Newly installed Clifford G5 Cat 1 Alarm with Warn away Zone sensor.
This car will now be broken - Details to follow
I have to admit that it would be a shame that a car as clean as this could be broken.
However I was thinking about the value of mine the other day, and I believe I could get as much for it in parts as i could as a complete car. It may be the start of an era where a lot of Supra's disappear!
And then we will get out of this recession and their prices will go back up as they are rarer!:D
This is a clean car and it's a shame that it'll most likely be broken. I'll still be vulturing for a few parts though!:eyebrows:
I´m interested seriously quite a while for now.
I should have recieved pics on last week wednesday, then it was Saturday - I recieved them on sunday.
I´m still waiting for more detailed shots and the areas I told you...
So what´s happening now, Richard ?
