change rear pads without fluid coming out?
Lude
This reminds me of the poor chap who died down Southampton way many years ago. He'd dinged his wheel and everyone told him not to drive the car, some were offering him their spare alloys for free. Yet he went ahead, and the wheel failed at speed, killing himself and a motorcyclist.
Don't be another like that.
The way i read this is, you split the 2 halves of the caliper body but didn't remove the pistons ?
The concern here is there are 2 seals that go between the 2 halves and if you didnt know they were
there then its very possible for them to fall out.
Did you see these seals ?
I strongly suggest at the very least you take the wheel off and have a good look round the caliper for brake
fluid, or as suggested get someone to have a look at the caliper or send it to dude to take it apart.
The 2 seals im on about dont come in the refurb kits and you can't get them from Toyota either.
No dnk pistons are out as well in his pic so it all needs checking to be on the safe side.
:D
Sorry for laughing.
You won't be the first or last to do this I would imagine, you learn from your mistakes. :)
im sorry but i hope you are wrong! there is no way you can split the calipar by misstake it is obviuos what bolts to undo to get it off the hub (which is not what the title says), there seems to be alot of back tracking going on from the op!
toyota even say not to split the caliper when you get the refurb kit!
there is no need what so ever to split them at all the mind boggles people with no clue should at least research about the job they are going to do, not ask questions after they have done it wrong!
i know when i have to do a spot of light reading it is a information full forum all you have to do is search for it.
you said he wont be the last, i hope he bloddy well is :D
Yes, it's the last thing you want to do. :)
A straightforward job turns into a right mess, I suppose you can take the opportunity to overhaul them.
I appologise again for laughing in my previous post. ;)
None of us are perfect, most of us have done stupid things over the years and you cannot believe what you did when you look back. :blink:
the pic i listed isnt my pic, its an example to show where the caliper was split, the 2 halves,
i didnt remove the pistons, or any seals, it split open, for about 5 mins while i retapped the wheel stud,
then i put the 2 halves back together again, bolted up tight, stopped leaking instantly, and no fluid leaked,
this was at least 2 months ago i did this, and all has been fine, but will be sending off to dude just incase.
i didn split, remove all seals and re use them, the caliper was split and put more or less straight back together
Edited by Lude (see edit history)
I'd be tempted to take the caliper off (don't split it) check ur seals are in place and 100% sealed.
Remeber there your brakes, the larst thing u want is it to leak while your driving
Next time you do this, as stated it very easy just take the two pins out don't split it.
I am sure craig will help you out if u get stuck.
Edited by J_Supra_07 (see edit history)
dude, you sure this is a good idea offering your services, what if it doesnt get put back on properly, or doesnt bleed them correctly. Ill be blaming you then
Well hes already had it off once and got it back on, he's also bled it, at the end of the day if he can't bleed it he cant drive it !!!! I can only check the integrity of the seals in the caliper. This is no diff to someone buying a caliper from me and me posting it. hopefully the guy who bought my T6 manifold and turbo won't crash because he's going too fast cause that will be my fault as well.
