Random Emissions question - Mapping info.
Scott
Just thinking out loud really. With all the options on modern ECUs I was wondering if it would be possible to have an emissions friendly map for when the cars need to go in for their MOTs. What actually causes high emissions levels? Would it be possible to have a "lean map" toggle that could be switched to for when the car goes in for an MOT?
Unburnt fuel causes high hydrocarbons, which produces excessive carbon monoxide. If you can get the air/fuel ratio as close to 14.7:1 as possible, it'll burn efficiently and be cleaner. My NA went through with no cats, 0.18% CO and 10ppm HC, possibly because i replaced the fuel pressure reg about 3k miles ago, I dunno. When it was last at SRR, Charlie commented on how good the air/fuel ratio was throughout the range.
I imagine a switchable map is do-able. Girly and Mental. :-D
Sent from my iPhone
Sent from my iPhone
That's easy to do on an N/A though, getting it to work that way on a single turbo where the tubby is starting to spool is going to be difficult.
I used to have to tweak my EMU map on my old S14 to get it through MOTs so quite doable.
Sounds good to me. I'll see what Ryan can do for me :D
By the way, my main reason for thinking of this was because I got a road side emissions check the other day. To be able to pull up to one and flick a switch would be like a get out of jail card I would imagine. Obviously very handy for MOTs as well though :)
