Big single kit ( precision turbo) £1000
Guest kenblockseal
Guest kenblockseal
This kit was making [email protected] on the engine
Its a Precision turbo witha ported shroud around the same size as a T04Z. there is no play and the turbo is in good order.
It has a XS Power manifold with brace
Unknown make external wastegate.
3 Inch Vband downpipe included.
I will also include a 3 inch stainless exhaust sustem which was side exit on a L200, but could be modified to suit if wanted.
Inlet pipe with new K&N Filter included
Oil & water lines.
Im after £1000
Cheers
Guest kenblockseal
I cant be 100 percent sure, but going by the person who built the car, and the person who bought it, weve worked it out to be less than 5000 miles.
Cheers.
Guest kenblockseal
Hi Michel,
I looked today but there was no part numbers just AR.70 7 AR.68
my friend looked today and said it was a ball bearing turbo, is there a definitive way to check? heres some pictures -
if this can be used for an NA-T conversion then i might be intrested
You can use it for an na-t conversion though the manifold is different as its designed for a 2jzgte. So you could sell the manifold included and buy one designed for the 2jzge.
