leesupra12 Posted October 7, 2011 Share Posted October 7, 2011 hi does anyone no if the map sensor from a 2jzge run the 1jzgte engine ok as it seems to be running ruff and im not sure if it would be the map sensor. if so does any body have a 1jzgte map sensor for sale. thanks lee Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 7, 2011 Share Posted October 7, 2011 Congrats on getting the flippin' thing running anyway buddy! I can't help you on the rough running as I've still to even hear mine fire up! Quote Link to comment Share on other sites More sharing options...
leesupra12 Posted October 7, 2011 Author Share Posted October 7, 2011 cheers bud i think thats what my problem is map sensor. had some really good help from the australian forum. there right on it. i have fitted the straight through exhaust now ,big intercooler getting there slowly its just the idle and the smoke now which would be i think the map sensor. fingers x it is. Quote Link to comment Share on other sites More sharing options...
Shane Posted October 7, 2011 Share Posted October 7, 2011 The oem map sensor used on a 2jzge does not recognise boost over about 0.5psi so I cant see how it could work on the gte once you came up to positive pressures. I came across this a few years ago when I was messing around trying to supercharge a NA. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 7, 2011 Share Posted October 7, 2011 Not trying to teach you how to suck eggs but do make sure that the wiring to the coilpack connectors, the connector bodies, and the packs themselves are in good order, if you haven't already done so. Quote Link to comment Share on other sites More sharing options...
leesupra12 Posted October 7, 2011 Author Share Posted October 7, 2011 cheers i have ordered a 1jzgte map sensor now. and would the ge map sensor cause the car to run like the spark plugs are off. i will check the coilpack and connectors thanks for that Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 7, 2011 Share Posted October 7, 2011 cheers i have ordered a 1jzgte map sensor now. and would the ge map sensor cause the car to run like the spark plugs are off. i will check the coilpack and connectors thanks for that Its just one of the many things that can cause an engine to run badly Lee, its impossible for me to say for definite what your problem is due to. Did you get that email I sent you a while back? Quote Link to comment Share on other sites More sharing options...
leesupra12 Posted October 7, 2011 Author Share Posted October 7, 2011 no i had no email bud. the new map sensor should be here middle of next week i will have to wait and see if it sorts it i will get a vid up soon so its easier to explain. cheers Quote Link to comment Share on other sites More sharing options...
mobius Posted October 7, 2011 Share Posted October 7, 2011 Lee speak wifh smiffie on http://www.soarerworld.com/forum/ specialises in soarers and always has parts lying around as in container loads. email him direct on [email protected] Quote Link to comment Share on other sites More sharing options...
leesupra12 Posted October 7, 2011 Author Share Posted October 7, 2011 does any body no why my profile thing says membership due Quote Link to comment Share on other sites More sharing options...
leesupra12 Posted October 7, 2011 Author Share Posted October 7, 2011 thanks for that mobius. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 7, 2011 Share Posted October 7, 2011 Full membership to the club is £10 per year and worth every penny of it. If you can find the thread I posted in Supra chat a while ago about the soarer body plugs you'll find a nice table of useful info at the end of it. It may or may not still be of use to you but I did send you a link to it via email as soon as I found it. Quote Link to comment Share on other sites More sharing options...
leesupra12 Posted October 7, 2011 Author Share Posted October 7, 2011 ill go look now Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 7, 2011 Share Posted October 7, 2011 http://www.mkivsupra.net/vbb/showthread.php?254441-JZZ30-1JZ-Harness-Plugs&highlight=soarer No need! Quote Link to comment Share on other sites More sharing options...
leesupra12 Posted October 7, 2011 Author Share Posted October 7, 2011 thanks i have all the wire pinouts for both looms now from wilbro and i have every wire connected check it out on toymods. its under 1jzgte help needed Quote Link to comment Share on other sites More sharing options...
