Florin Posted October 6, 2011 Share Posted October 6, 2011 Replaced the tensioner with brand new one and 9 miles later it jumped again.... The belt has 50 miles on it and does not look damaged at all..Also I'm having a hard time figuring out what this little spacer star looking thing thats behind the dapner is called???? Is that what sends the signal to the spark plugs??? if so does it do it via a sensor reading the teeth?? does that sensor go bad, Is there a way to check if its doing what its supposed to do before I start just replacing parts for the hell of it Been working on this car for 10 months and have drivin it a total of 2 hours. I just cant figure it out and the only ppl around that can help me want 70$ an hour. I just cant give a guy 3 or 4 hundered eveytime theres a slight problem or a new noise I havent heard before. Spent 1000$ for him to put a man boost controller on, cut out defender, and weld some pipes on the intake. The car ran great for a cpl of days and now I have a new problem with this timing,engine dying, not startinf right thing and I just cant afford to turn around and give him another 1000$ just coz he knows his shit and can fix it in 30 mins .....Meanwhile he can tell me he did this and that and I wouldnt know the diffrence. Please help.... Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 6, 2011 Share Posted October 6, 2011 the only time ive seen something similar is when someone t5urned the crank with the cams locked and pulld it past 2 teeth. the bel looked fine but when it was reset it kept jumping teeth so he binned it and fitted a new belt and the prob was solved Link to comment Share on other sites More sharing options...
Scott Posted October 6, 2011 Share Posted October 6, 2011 Where is it jumping the teeth? Is it down at the pulley it's jumping or is it the cams? One or both? Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 Where is it jumping the teeth? Is it down at the pulley it's jumping or is it the cams? One or both? The first time both cam gears were clock wise off by 5 teeth each from the sign on the back plate...... Took the belt off got everything tdc and put new tensinor on drove it 9 miles it back fired once then died got out to look and now it looks like the intake cam gear is off by 2 teeth clock wise and the other is right on the money. The car will start pretty easy and sound norm (as your turnig it over) but once it starts the rpm just goes up and down 700 to 1300 or so , try to take off and it jolts some if the makes any sense when that happend i just parked it.... To the first reply....What would lock the cams to begin with???? In order for "someone t5urned the crank with the cams locked" what is the "bel" what is "binned" Thank you very very much guys Link to comment Share on other sites More sharing options...
wile e coyote Posted October 6, 2011 Share Posted October 6, 2011 (edited) Is it a tt ? if so you may have bent a valve or 2 causing it to stick and make the belt jump With it a tdc take belt off and try turning each cam feeling for any tightness Edited October 6, 2011 by wile e coyote (see edit history) Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 If that*** If feels like you would be running out of gas when you try to take off i should say. Thats why other then the timing belt issue. I'm wondering if the spark, spark plugs, coils, coil plugs, and whatever sends the plugs there signal might be the problem, I think the peace is called the "trigger" ?? ...also it might ( just guessing here) have something to do or be the mass air flow sensor?? I know Ive rambeld a bit and that I might be stating facts about diff problems but I thought it would help get a better idea of the car 94 tt 6 spd a cpl of bpus and a bypassed vsv under the front turbo Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 Is it a tt ? if so you may have bent a valve or 2 causing it to stick and make the belt jump With it a tdc take belt off and try turning each cam feeling for any tightness but isnt the car a non-interference engine??? if so then the valve cant get bent ???? Link to comment Share on other sites More sharing options...
Swampy442 Posted October 6, 2011 Share Posted October 6, 2011 The TT is a non interference engine. Did you use a genuine Toyota tensioner and pulley? Was the timing set up correctly? Are the cam gears aftermarket or stock? I call that star thing a trigger wheel or timing star, its teeth are counted by the crank position sensor. Generally if the cps is shot the engine wont start at all. Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 Thats what I thought also. The trnsioner I got from the dealer. The belt from auto parts store. The cams are stock. Did not replace any pullys. not sure if the first time it was done right but am sure the second time it was. tdc etc.... Link to comment Share on other sites More sharing options...
Scott Posted October 6, 2011 Share Posted October 6, 2011 Are you fitting the tensioner via the manual? As in putting an allen key in it to pre-tension it so that the belt isn't getting the force? Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 Are you fitting the tensioner via the manual? As in putting an allen key in it to pre-tension it so that the belt isn't getting the force? Not really sure what you mean. I dont have a manual..... Link to comment Share on other sites More sharing options...
TRD DAN Posted October 6, 2011 Share Posted October 6, 2011 Pictures would be best dude let's have a look at what Your seeing Dan Link to comment Share on other sites More sharing options...
Scott Posted October 6, 2011 Share Posted October 6, 2011 Not really sure what you mean. I dont have a manual..... The tensioner puts a silly strain on the timing belt if it isn't fitted correctly. The correct way to do it is to put the tensioner in a press and align up the holes so that you an fit a 1mm or 1.5mm allen key through them. You then take the pressure off and fit the tensioner in place. Once it's in and secured you pull the allen key out and the correct pressure will be put on the belt. It takes a lot more force to compress the tensioner than it does to hold it in place, if you screw the tensioner in without pre-loading it you will over strain the timing belt. Link to comment Share on other sites More sharing options...
dude Posted October 6, 2011 Share Posted October 6, 2011 Ill bet you are winding the tensioner in on the 2 12mm bolts that hold it to the timing cover, if so thats your problem. Link to comment Share on other sites More sharing options...
wile e coyote Posted October 6, 2011 Share Posted October 6, 2011 but isnt the car a non-interference engine??? if so then the valve cant get bent ???? yeh sorry your right mines a vvti and we not sure on that one Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 Ill bet you are winding the tensioner in on the 2 12mm bolts that hold it to the timing cover, if so thats your problem. All this tensioner talk could VERY well be my problem!!! But the NEW tensioner came with a pin in it. So I just bolted it on put the belt on the pulled the pin,,,,Correct or no??? Will try to post some pics, but i think last time i tried to put some of the car it didnt work to well I might dont be doing it right the (uploading).... Link to comment Share on other sites More sharing options...
dude Posted October 6, 2011 Share Posted October 6, 2011 All this tensioner talk could VERY well be my problem!!! But the NEW tensioner came with a pin in it. So I just bolted it on put the belt on the pulled the pin,,,,Correct or no??? Will try to post some pics, but i think last time i tried to put some of the car it didnt work to well I might dont be doing it right the (uploading).... Thats the correct way to do it dude, so thats not the problem, are you definatly getting the tight side of the belt on the short run down from the cam pulley on the inlet side arent you Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 (edited) It appears that on the exhaust side the belt is tighter then on the intake side, is that also correct ?? But either way how can one adjust wich side gets tighter .. Edited October 6, 2011 by Florin (see edit history) Link to comment Share on other sites More sharing options...
dude Posted October 6, 2011 Share Posted October 6, 2011 Right, the tension needs to be from the inlet pulley to the crank pulley, it should be tight and all slack is between crank and ex pulley, this is where the tensioner does its job, tensions and removes slack, if you have slack between in pulley and crank as the engine cranks the the crank can pull the belt round without it pulling on the inlet pulley and moving the cam pulleys at the same time. Link to comment Share on other sites More sharing options...
Scott Posted October 6, 2011 Share Posted October 6, 2011 Is the belt definitely the correct one? It might just have been me but even with the tensioner off I had a hell of a time getting my belt on due to just how tight a fit it was when "loose". Or is there something wrong at my end? All I did was put the belt on, give the pulley a small turn to put as much tension on the inlet side as I saw fit and then mated up the tensioner before pulling the allen key. Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 Also I have another question. If the car is running rich to the point where you can smell fuel and yet it wants to stall.... what would be somethings to check first???? Link to comment Share on other sites More sharing options...
Scott Posted October 6, 2011 Share Posted October 6, 2011 Personally I would probably strip down the turbo pipes, intercooler pipes etc. Give them all a good clean and quick inspection then put it all back together. A few of the stock rubbers between the turbo outlets are known to collapse. No harm in giving everything in that area a good going over to be sure that everything is as it should be. Link to comment Share on other sites More sharing options...
Florin Posted October 6, 2011 Author Share Posted October 6, 2011 It wants to stall in 3d- 4th -5th when its between 1500 and 2200 rpm I know thats when right around where the turbos kick in. so you take off in first with any issues (not stepping on it ) just like you were driving a corolla the go to second and third now you step on it and it wants to stall but after you pass 2500 its fine... same thing with 4th 5th Link to comment Share on other sites More sharing options...
Scott Posted October 6, 2011 Share Posted October 6, 2011 Sounds to me like it's misfiring bud. I've had that before with dodgy coilpacks. Link to comment Share on other sites More sharing options...
