TopSecret1 Posted October 6, 2011 Share Posted October 6, 2011 (edited) My friend bought a 1996.7 SZ-R 6-speed Supra. This is the facelift version. Does anyone know if this car should come with LSD? He got it for cheap but everything works good, he will be using the cars chassis of the car since his other Supra was in a big accident. He will be transfering most of his parts on the new chassis. ASSUMING it has LSD. Is it possible to remove the LSD. Then when its removed put it in a GS400 3.26 open differenital. Then when his LSD is removed his differential can be put back together and work normally (without LSD)? he will be driving the car around for a bit before he rips it apart he said. I bought a GS400 differential because I still have the 4.30 5-speed differential. My car was swapped about 8 years ago. It feels very sluggish with the super short gearing. Edited October 6, 2011 by TopSecret1 (see edit history) Link to comment Share on other sites More sharing options...
TopSecret1 Posted October 6, 2011 Author Share Posted October 6, 2011 from research I was able to gather they come standard with LSD? just wanted to find out if that swap will work, cheers guys. Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 6, 2011 Share Posted October 6, 2011 look at the vin plate under the bonnet. if it has a b at the end of the trans.axle code itl be torsen. e.g. ao1b is torsen a01a is open Link to comment Share on other sites More sharing options...
TopSecret1 Posted October 6, 2011 Author Share Posted October 6, 2011 I called my friend and he checked, its Torsen my question is: can I take it out of his differential, then put his differential back together so it works? I then wanted to use this differential for my GS400 lexus open diff. thank you! Link to comment Share on other sites More sharing options...
