1996.7 SZ-R 6-speed... LSD?
TopSecret1
My friend bought a 1996.7 SZ-R 6-speed Supra. This is the facelift version.
Does anyone know if this car should come with LSD?
He got it for cheap but everything works good, he will be using the cars chassis of the car since his other Supra was in a big accident. He will be transfering most of his parts on the new chassis.
ASSUMING it has LSD.
Is it possible to remove the LSD. Then when its removed put it in a GS400 3.26 open differenital.
Then when his LSD is removed his differential can be put back together and work normally (without LSD)? he will be driving the car around for a bit before he rips it apart he said.
I bought a GS400 differential because I still have the 4.30 5-speed differential. My car was swapped about 8 years ago. It feels very sluggish with the super short gearing.
Edited by TopSecret1 (see edit history)
I called my friend and he checked, its Torsen :)
my question is:
can I take it out of his differential, then put his differential back together so it works?
I then wanted to use this differential for my GS400 lexus open diff.
thank you!
