gavin.starr Posted October 5, 2011 Share Posted October 5, 2011 (edited) I would really appreciate it if some one could come and take a look at my supra to diagnose my engine rattle that has developed. I currently cant drive it as i dont want to make the problem worse. So unfortunatly you will have to come to me. It would be greatly appreciated as i would like to get to the bottom of the problem. The car is currently sat on my mothers drive feeling sorry for itself, I wont give out its exact location as i dont want a randomer seeing this post and trying to nick it, but is is being kept in a village called Freckleton, which is just outside of Preston Lancashire. Any help would be great, I need to know how much it is likely to cost to repair it, as this will be my deciding factor for if im going to keep it or not. Gutted:( Many thanks Gavin Edited October 7, 2011 by gavin.starr (see edit history) Link to comment Share on other sites More sharing options...
Swampy442 Posted October 5, 2011 Share Posted October 5, 2011 Moar info. When does it rattle, hot/cold/revs dependant. Its probably something simple so dont panic just yet. Id take a look but Im miles away sadly Link to comment Share on other sites More sharing options...
add heywood Posted October 6, 2011 Share Posted October 6, 2011 Video...? Link to comment Share on other sites More sharing options...
Dnk Posted October 6, 2011 Share Posted October 6, 2011 Video it and give us more info, too far to come for me but im sure someone local will pop round and have a listen Link to comment Share on other sites More sharing options...
gavin.starr Posted October 7, 2011 Author Share Posted October 7, 2011 Sorry folks , i havent managed to reply for a while, i did take a video but the sound isnt clear. i will try and upload it in a min Link to comment Share on other sites More sharing options...
gavin.starr Posted October 7, 2011 Author Share Posted October 7, 2011 [video=youtube;qR8-srJ1yw4] This was the video i took, i didnt want to rev it to hard but it basically comes in around 2-3k but gets louder the hotter the engine gets, it seems to be quite quiet when its cold. Link to comment Share on other sites More sharing options...
add heywood Posted October 7, 2011 Share Posted October 7, 2011 That doesnt sound good Link to comment Share on other sites More sharing options...
gavin.starr Posted October 7, 2011 Author Share Posted October 7, 2011 I know it making me feel ill at how much it is likeley to cost me if i were to repair it, and how much i would loose on a sale if i decide to sell it. Very sad times. Link to comment Share on other sites More sharing options...
Dnk Posted October 7, 2011 Share Posted October 7, 2011 Sounds top end to me so could be cam related. Has it had regular oil changes with quality oil ? also what kind of miles is it supposed to have done ? Link to comment Share on other sites More sharing options...
gavin.starr Posted October 7, 2011 Author Share Posted October 7, 2011 It has done relitivley high miles, around 120k, and yes i have done all the oil changes myself with silkolene pro s oil at regular intervals. Link to comment Share on other sites More sharing options...
Dnk Posted October 7, 2011 Share Posted October 7, 2011 120k isnt high on a well looked after 2jzgte engine Link to comment Share on other sites More sharing options...
gavin.starr Posted October 7, 2011 Author Share Posted October 7, 2011 Do you have any ideas on what it could be then? Link to comment Share on other sites More sharing options...
Scooter Posted October 7, 2011 Share Posted October 7, 2011 I'm no expert, but I would remove the fan belt and then start her briefly and do the same rev test...........if the noise is the same then this will eliminate the ancillaries driven by the belt and leave you with a possible cam belt tensioner wheel issue or engine innards somewhere Link to comment Share on other sites More sharing options...
Guest kenblockseal Posted October 7, 2011 Share Posted October 7, 2011 Sounds like big ends to me, Jack the front wheels off the ground then see where the noise comes from. Link to comment Share on other sites More sharing options...
justice Posted October 7, 2011 Share Posted October 7, 2011 sounds like the big end too me aswell. I got shown this on another supra while at the garage and, Paul called it the 'death rattle'.... Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted October 7, 2011 Share Posted October 7, 2011 it sounds like your buckets are worn making a valve clatter ( you might get away with just shimming it) your head needs refurbed to be fair. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted October 7, 2011 Share Posted October 7, 2011 That doesnt sound good similar noise to your old head when the buckets were worn, ok when cold and not so when warm.. btw feel free to call me over weekend for next lot of work Link to comment Share on other sites More sharing options...
dude Posted October 7, 2011 Share Posted October 7, 2011 Sounds like big ends to me, Jack the front wheels off the ground then see where the noise comes from. Spot on Nothing like top end, its a big end bearing, sounding like that the crank is more than likely junk as is the con rod and oil pump. Link to comment Share on other sites More sharing options...
add heywood Posted October 7, 2011 Share Posted October 7, 2011 similar noise to your old head when the buckets were worn, ok when cold and not so when warm.. btw feel free to call me over weekend for next lot of work Will do tomorrow Jurgen IMO doesnt sound like my upper engine problem I had, as mine was constant throughout the rev range, where as this is confined to a certian rev range. Sounds exactly like when my old rs turbo engine spun a bearing... Link to comment Share on other sites More sharing options...
supralu Posted October 7, 2011 Share Posted October 7, 2011 Sounds exactly like mine did last month. It was the big ends. I just got a replacement engine fitted from Keron. Good luck getting it sorted mate. Link to comment Share on other sites More sharing options...
Iky Posted October 7, 2011 Share Posted October 7, 2011 Ive heard knacked big ends on another car and am afraid that video does sound pretty much the same. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted October 7, 2011 Share Posted October 7, 2011 Will do tomorrow Jurgen IMO doesnt sound like my upper engine problem I had, as mine was constant throughout the rev range, where as this is confined to a certian rev range. Sounds exactly like when my old rs turbo engine spun a bearing...yes your right mate yours was through full revs Link to comment Share on other sites More sharing options...
Graham Read Posted October 7, 2011 Share Posted October 7, 2011 if unsure give me a ring only in darwen would be happy to have a listen in the FLESH 07969823802 Link to comment Share on other sites More sharing options...
dude Posted October 8, 2011 Share Posted October 8, 2011 if unsure give me a ring only in darwen would be happy to have a listen in the FLESH 07969823802 WOW not only is Graham happy to go round and have a listen but he will do it naked !!!!! Its spun an end shell in a rod, cheapest way out is a second hand bottom end/engine Link to comment Share on other sites More sharing options...
gavin.starr Posted October 8, 2011 Author Share Posted October 8, 2011 How much we looking for a replacement complete block, without ancillaries just a working block? I kind of feared every one was going to say this. If it is too much to repair im afraid im going to have to sell it and take a loss:( Link to comment Share on other sites More sharing options...
