JMB Posted October 4, 2011 Share Posted October 4, 2011 Hi all I'll install my downpipe (catless) this week, but I do not have any 02 sensor's hole. Should I do one ? If so, as I will run catless, will I have an engine error code ? waiting to read you Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 4, 2011 Share Posted October 4, 2011 iirc you can just tie it out the way Quote Link to comment Share on other sites More sharing options...
JMB Posted October 4, 2011 Author Share Posted October 4, 2011 are you sure ? I was afraid of that As many downpipe like the HKS has a 02 hole. Anyway i'll do a special hole for my AFR gauge Quote Link to comment Share on other sites More sharing options...
trinitom Posted October 4, 2011 Share Posted October 4, 2011 you may get a error code by removing the o2 sensor, or the cat malfunction light on the top left. And i think the best place to install the afr sensor, should be on the second decat. Quote Link to comment Share on other sites More sharing options...
JMB Posted October 4, 2011 Author Share Posted October 4, 2011 thanks for the AFR advice. Concerning the o2 sensor, should I install it with an "o2 cheater" ? Quote Link to comment Share on other sites More sharing options...
trinitom Posted October 4, 2011 Share Posted October 4, 2011 you can just remove it, and unplug the little lamp from the cat malfunction indicator. job done. Quote Link to comment Share on other sites More sharing options...
hodge Posted October 4, 2011 Share Posted October 4, 2011 Are we talking the actual O2 sensor or the cat temp sensor which is in the cat. If it's the cat temp sensor, lift the carpet up in the drivers side and it will unplug and pull out the hole. Then all is left to do is put another grommet in. If you do mean the O2 sensor the car won't run correctly without it. It will eventually overfuel very badly and foul the plugs. Quote Link to comment Share on other sites More sharing options...
JMB Posted October 4, 2011 Author Share Posted October 4, 2011 you can just remove it, and unplug the little lamp from the cat malfunction indicator. job done. Excuse but as I am not an expert lol How can I unplug the lamp. I was asking concerning the sensor because on my rx8, when I removed it the car wasn't running well. Quote Link to comment Share on other sites More sharing options...
JMB Posted October 4, 2011 Author Share Posted October 4, 2011 Are we talking the actual O2 sensor or the cat temp sensor which is in the cat. If it's the cat temp sensor, lift the carpet up in the drivers side and it will unplug and pull out the hole. Then all is left to do is put another grommet in. If you do mean the O2 sensor the car won't run correctly without it. It will eventually overfuel very badly and foul the plugs. I was talking about the 02 sensor wich is plugged in the midpipe's cat. any solution ? Quote Link to comment Share on other sites More sharing options...
trinitom Posted October 4, 2011 Share Posted October 4, 2011 i think you are confused about this, the o2 sensor is not located on the cat. like hodge said that's the cat sensor. Quote Link to comment Share on other sites More sharing options...
Josh Posted October 4, 2011 Share Posted October 4, 2011 i think you are confused about this, the o2 sensor is not located on the cat. like hodge said that's the cat sensor. Unless it's a UK Spec IIRC. Quote Link to comment Share on other sites More sharing options...
JMB Posted October 4, 2011 Author Share Posted October 4, 2011 i think you are confused about this, the o2 sensor is not located on the cat. like hodge said that's the cat sensor. Ok thanks, because i looked at the diy & it was talking about o2 sensor : http://mkiv.com/techarticles/downpipe/downpipe.htm Quote Link to comment Share on other sites More sharing options...
JMB Posted October 4, 2011 Author Share Posted October 4, 2011 Unless it's a UK Spec IIRC. It s a jdm 98 vvti model Quote Link to comment Share on other sites More sharing options...
