Guest marcelus Posted October 3, 2011 Share Posted October 3, 2011 Hi i have a mkiv supra which just of late has been playing up its an 1993 jap import and it started off not running very well after been stood for a little while and then progressed to not starting after it had been stopped , bit of a weird one but hey ho i always seemed to get it started again some how but now it won't start unless you switch the overdrive off which i found out completely by accident but its true ,so i'm left wondering what may be causing this ? oh and when your driving it with the overdrive on its a bit sort of lumpy bit hesitant . It has a de-limiter on it so was wondering if thats the problem and i should maybe remove it and wire it back up to its original spec many thanks mark Quote Link to comment Share on other sites More sharing options...
