compression test on 1jzgte HELP!
suprasize
Okay, so ive been plotting to do a 1jz gte conversion on.my na and want a perfect candidate and think I may have found it until I got back the results of a compression test...
the test found that 5/6 cylinders had readings between 0-10% which apparently very good.. =) however, cylinder 5 showed a leak of 40%... Im no mechanic but is that extremely bad or okay?
He reckons Its good for a secondhand engine, but how true is that? Im not questioning this guy's ability and hes been so open and informative through this engine hunt.. Should I bite the bullet and take this?
Need everyone's thoughts! =)
Many Thanks
Dan
Thats good =) that one was on a private for sale thread on driftworks, the other with the 40% leak was from nickson motorsport off DWs webby aswell, I know what you mean though just want to find a perfect candidate for.my conversion =( everything is so expensive though =(
Okay, ive a had a bit of joy on the first engine. Apparantlythis test wasn't a compression test but a leak down test whereby a constant pressure of 100psi is passed through the cylinders constantly whilst all valves are closed. Thks should show any leaks including piston rings etc
There was no leaks through the piston rings to the crank cawe whatsoever it was a leak on one valve out of 24 which apparently is very good, hes going to leak down test the other engine for me but strongly doubts itll have as good a compression as this one.
He did say he would remove the head but it's an additional ,l £100 for the parts as well as a days labour to remove the head and work.on valves.
