p3te Posted October 2, 2011 Share Posted October 2, 2011 I did a jspec to uk brake conversion on my car yesterday, got it all done and handbrake adjusted up but noe my triangle warning light is permenantly on, what have i done and how can i fix it? Quote Link to comment Share on other sites More sharing options...
monsween Posted October 2, 2011 Share Posted October 2, 2011 Brake fluid level is too low Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted October 2, 2011 Share Posted October 2, 2011 Low fluid level? Try shorting the switch on master cyl. Quote Link to comment Share on other sites More sharing options...
p3te Posted October 2, 2011 Author Share Posted October 2, 2011 The fluid was actually nearly on the min so i topped it up, what do you mean short the switch? Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted October 2, 2011 Share Posted October 2, 2011 Stick a paperclip across the terminals on the block connector, if it goes off you've got a faulty low fluid level switch. Quote Link to comment Share on other sites More sharing options...
p3te Posted October 2, 2011 Author Share Posted October 2, 2011 Is this the connector that goes into the brake fluid tank? It was ok before i changed the brakes does that matter? Quote Link to comment Share on other sites More sharing options...
Bossco Posted October 2, 2011 Share Posted October 2, 2011 It could be that your hand brake isnt fully releasing??? Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 2, 2011 Share Posted October 2, 2011 It could be that your hand brake isnt fully releasing??? I'll have a quid on that if the fluid level is ok in the m/c Quote Link to comment Share on other sites More sharing options...
hodge Posted October 2, 2011 Share Posted October 2, 2011 Low fluid level? Try shorting the switch on master cyl. Stick a paperclip across the terminals on the block connector, if it goes off you've got a faulty low fluid level switch. It doesn't work like that. When the connector is plugged in and the fluid level is high enough it stops it from making a circuit when the level drops the circuit is made and the light comes on. If you simply unplug it the light will go out. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted October 2, 2011 Share Posted October 2, 2011 It doesn't work like that. When the connector is plugged in and the fluid level is high enough it stops it from making a circuit when the level drops the circuit is made and the light comes on. If you simply unplug it the light will go out. Mine must be back to front then. I removed the plug and the light came on. Wouldn't go out until I shorted the terminals. I've removed my switch wiring. Do you still have a warning triangle light on that dash John? Quote Link to comment Share on other sites More sharing options...
nevins Posted October 2, 2011 Share Posted October 2, 2011 How did you adjust it, if you done it internally as well check that you did not manage to disturb the switch on the lever. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted October 2, 2011 Share Posted October 2, 2011 Just a thought, if its the handbrake, you get the other little red light too. Does this come on and go off as you operate the handbrake? If so, it's not that. If it stays on though, ^^ what these guys are saying is as close as your going to get. Quote Link to comment Share on other sites More sharing options...
p3te Posted October 2, 2011 Author Share Posted October 2, 2011 all is fine now, i put in more fluid and went for a drive and it went off:blush:, and i adjusted the handbrake with the adjusters on the back hubs, Bossco It could be that your hand brake isnt fully releasing??? now you say that sometimes when i release the handbrake now, especially if its been on a bit it dosent fully release untill i drive it, i thought it might be a bit paint on the inside of the hub sticking and it would wear off? Quote Link to comment Share on other sites More sharing options...
Bossco Posted October 2, 2011 Share Posted October 2, 2011 Sounds more like a sticky caliper than the handbrake. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted October 2, 2011 Share Posted October 2, 2011 Can you spin the wheel easily by hand with the h/b off? Quote Link to comment Share on other sites More sharing options...
p3te Posted October 2, 2011 Author Share Posted October 2, 2011 Sounds more like a sticky caliper than the handbrake. if its sticky would it not be on all the time? it seemed fine before i fitted, when it sticks its as if the car has been stood a while the handbrake sticks on, and when the car moves again its like the seal is broke and it moves freely again. Quote Link to comment Share on other sites More sharing options...
p3te Posted October 2, 2011 Author Share Posted October 2, 2011 Can you spin the wheel easily by hand with the h/b off? yep, Quote Link to comment Share on other sites More sharing options...
hodge Posted October 2, 2011 Share Posted October 2, 2011 Mine must be back to front then. I removed the plug and the light came on. Wouldn't go out until I shorted the terminals. I've removed my switch wiring. Do you still have a warning triangle light on that dash John? I've done loads of tucks on supras now and when I cut off the wires it doesn't show any fault or lights. I've just done Bosscos today with no issues. Your car must be special lol. Quote Link to comment Share on other sites More sharing options...
Havard Posted October 3, 2011 Share Posted October 3, 2011 Just for reference, I had the same problem with the light on and it was just a wee bubble of air in the system. Bled the brakes again and the light went off. Looks as if it was your level though on this occasion. H. Quote Link to comment Share on other sites More sharing options...
