Wi-Fi Connection problem
Tee from China
I'm hoping that some knowledgeable sole's reading this and can help with the problem:sly:
I recently moved apartments through my job and in my old place I connected my router through the modem and all was fine except I couldn't lock the access to the router! :rolleyes:
Now the new place had/has Wi-Fi as the last occupant used it for his laptop. ;)
If I connect my desktop to the modem the Internet connects instantly, however if I connect the router as before the connection fails! :(
What am I doing wrong? I connected as before and know that the Wi-Fi was working a month ago!. I am using the existing and my own router but the problem is exactly the same. :(
Cant use my own modem as the one here now is not wired the same and there is no wall plug I can use and the wire for the line to the modem is not the usual plug either and connects inside - but as I said it was all working before so why the problems now? :blink:
Anyone got any answers?
Cheers Tee
