Xzarik Posted September 29, 2011 Share Posted September 29, 2011 So much as I want to do everything to my Sup myself, I decided that brakes were one of those safety things I should really not take the risk on, so I got a quote from a place in Leeds which is meant to be a Japanese Import Specialist... £150 to fix the squeaking brakes sound ok? I believe they're going to be fitting new discs and pads on the front for that price too. Also on a sidenote, anyone had any experience with Rising Sun Motors? Quote Link to comment Share on other sites More sharing options...
Josh Posted September 29, 2011 Share Posted September 29, 2011 Brakes are easy. The first (proper) job I did on a car was change the discs and pads on my Golf. If you're just changing those and fixing the squealing, it should be quite straight forward. Quote Link to comment Share on other sites More sharing options...
Xzarik Posted September 29, 2011 Author Share Posted September 29, 2011 Undoubtedly i'll be changing them at some point, but I need the car this saturday and I don't want to risk it; I can't think of anything more dangerous to screw up because i've not got the car on a driveway/in a garage and i'm rushing it! Quote Link to comment Share on other sites More sharing options...
qwarrior Posted September 29, 2011 Share Posted September 29, 2011 Discs, pads and labour for 150 sounds cheap if it includes parts. Are all of the parts stock? Quote Link to comment Share on other sites More sharing options...
Xzarik Posted September 29, 2011 Author Share Posted September 29, 2011 Great news I believe all the parts are just bog-standard stuffs. Quote Link to comment Share on other sites More sharing options...
imi Posted September 30, 2011 Share Posted September 30, 2011 surprising as the discs alone are 100 each. and decent pads would be around 70 for a pair. Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 30, 2011 Share Posted September 30, 2011 They wont be using o/e Toyota parts for that money, if i were you i'd ask the garage what they intend to do and fit so you know exactly what your getting for your £150. Changing front discs and pads is an hours work max, half an hour really but not many garages will charge for less than an hour for doing anything mechanical. UK spec discs are approx £75 each and the front pads will be around £50 for both front calipers. Im not sure about the price for the smaller brakes (2 piston fronts) but they'll be similar to the 4 pot UK set up Quote Link to comment Share on other sites More sharing options...
jim Posted September 30, 2011 Share Posted September 30, 2011 There's virtually no difference in price between jspec small and uk spec brakes, in fact I think the jspecs are a little dearer. Quote Link to comment Share on other sites More sharing options...
