hodge Posted September 28, 2011 Author Share Posted September 28, 2011 I really dont see what the arguement is, if you can afford it then yes, its a no brainer, I know from personal experience how good these are, it just comes down to money at the end of the day. I'd build it up over a while Paul so cost isn't really an issue as I'll just save for it and buy parts as and when required. I just don't know wether it's actually worth the money with my 76mm turbo because I love how the car drives ATM and don't want to spoil it. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2011 Share Posted September 28, 2011 I'd build it up over a while Paul so cost isn't really an issue as I'll just save for it and buy parts as and when required. I just don't know wether it's actually worth the money with my 76mm turbo because I love how the car drives ATM and don't want to spoil it. Its only going to make it better mate I promise. Link to comment Share on other sites More sharing options...
hodge Posted September 28, 2011 Author Share Posted September 28, 2011 Its only going to make it better mate I promise. You think its worth doing with a GT42-76 turbo 1.28 A/R. I'm just not sure Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2011 Share Posted September 28, 2011 You think its worth doing with a GT42-76 turbo 1.28 A/R. I'm just not sure Yeah, why are you thinking otherwise? Link to comment Share on other sites More sharing options...
hodge Posted September 28, 2011 Author Share Posted September 28, 2011 Yeah, why are you thinking otherwise? Just think to get the best out of it a bigger turbo would be the better option. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2011 Share Posted September 28, 2011 Just think to get the best out of it a bigger turbo would be the better option. I dont think thats true. They work just as well on a 600bhp engine as they do on a 1200bhp engine. Its only going to improve it and noticeable to. Link to comment Share on other sites More sharing options...
hodge Posted September 28, 2011 Author Share Posted September 28, 2011 I'm just trying to offset the gains against the money involved to build it. I'll mull over it for a while and see how we go I think. Link to comment Share on other sites More sharing options...
DARETT Posted September 28, 2011 Share Posted September 28, 2011 Have you seen the Spool on Kims 3.4l 88mm Turbo. I want to know if its his turbo or 3.4. I think he has the divided billet bb 88mm turbo, which is a great turbo on a 3.4. It's probably a mix of both. Someone I know had the same turbo setup on a built 3.0 but the spool was no where like that. The non billet 88 doesn't spool that well on a 3.4 either. With these big turbos a 3.4 is a must IMO. Link to comment Share on other sites More sharing options...
JamieP Posted September 28, 2011 Share Posted September 28, 2011 I wish i did 3.4 last time, i just could not justify spending the money before, ive talked myself round now Link to comment Share on other sites More sharing options...
greeny Posted September 28, 2011 Share Posted September 28, 2011 Stay 3.0l and keep the piston speeds and angles lower and lighten up the rotating parts. Then rev higher, more safely with a bigger turbo. Maybe bump the compression up slightly to make it even more responsive. With the control of good modern ecu's etc you can get away with more. The piston speeds on the 3.4 engines are getting pretty high! Link to comment Share on other sites More sharing options...
