Krister Posted September 30, 2011 Share Posted September 30, 2011 What exhaust housing blanket and wrap is that? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 30, 2011 Share Posted September 30, 2011 What exhaust housing blanket and wrap is that? I think its the dti stuff ( titanium) Link to comment Share on other sites More sharing options...
letmeshowyou Posted September 30, 2011 Share Posted September 30, 2011 Great vid Link to comment Share on other sites More sharing options...
RZ95 Posted September 30, 2011 Share Posted September 30, 2011 DEI Ti: http://www.designengineering.com/category/catalog/component-specific-productst/t4-titanium-turbo-shield-kit Link to comment Share on other sites More sharing options...
Ian C Posted September 30, 2011 Share Posted September 30, 2011 (edited) Here is a dyno with a comparrison to my buddy who had his car mapped by Ryan the day before me. It is actually the Supra seen in the background in the picture I posted earlier in this thread: http://peecee.dk/uploads/092011/KDW_SUPRA_VS_ANDERS_SUPRA2.jpg What is interesting is that at 5000 RPM I make 680 at the hubs compared to his 300, even though he has a much smaller turbo. You can't really compare the curves because something is off between them - look at the 2000rpm load point, you're at about 280ftlbs at 2000rpm which is quite high for an off-boost 2JZ motor, whereas Anders' Supra is off the bottom of the chart, well below 200ftlbs. As neither of you should be on any sort of boost at that point, the power outputs should be pretty much the same, barring minor NA breathing differences. It looks like either the dyno was loaded up more for your run so you got on boost early, or there was some sort of scaling issue. Edit - oops, that's newton metres, not foot pounds, but still, they are quite different at low revs for some reason Edited September 30, 2011 by Ian C (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted September 30, 2011 Share Posted September 30, 2011 You can't really compare the curves because something is off between them - look at the 2000rpm load point, you're at about 280ftlbs at 2000rpm which is quite high for an off-boost 2JZ motor, whereas Anders' Supra is off the bottom of the chart, well below 200ftlbs. As neither of you should be on any sort of boost at that point, the power outputs should be pretty much the same, barring minor NA breathing differences. It looks like either the dyno was loaded up more for your run so you got on boost early, or there was some sort of scaling issue. Change the run time from 10 seconds to 8 seconds on a dynapack and it makes a massive difference to the graph, i found this by mistake, i thought there was something wrong with my car, i lost 250 rhhp at 5000rpm just changing from a 10 second run to a 8 second run. Link to comment Share on other sites More sharing options...
imi Posted September 30, 2011 Share Posted September 30, 2011 You can't really compare the curves because something is off between them - look at the 2000rpm load point, you're at about 280ftlbs at 2000rpm which is quite high for an off-boost 2JZ motor, whereas Anders' Supra is off the bottom of the chart, well below 200ftlbs. As neither of you should be on any sort of boost at that point, the power outputs should be pretty much the same, barring minor NA breathing differences. It looks like either the dyno was loaded up more for your run so you got on boost early, or there was some sort of scaling issue. Details.....eh. Some people Link to comment Share on other sites More sharing options...
RZ95 Posted September 30, 2011 Share Posted September 30, 2011 You can't really compare the curves because something is off between them - look at the 2000rpm load point, you're at about 280ftlbs at 2000rpm which is quite high for an off-boost 2JZ motor, whereas Anders' Supra is off the bottom of the chart, well below 200ftlbs. As neither of you should be on any sort of boost at that point, the power outputs should be pretty much the same, barring minor NA breathing differences. It looks like either the dyno was loaded up more for your run so you got on boost early, or there was some sort of scaling issue. Edit - oops, that's newton metres, not foot pounds, but still, they are quite different at low revs for some reason As you pointed out in your edit it's Nm not ft/lbs, but my car makes more power down low than his car, higher CR and stroker is the main reasons. Link to comment Share on other sites More sharing options...
Ryan.G Posted September 30, 2011 Share Posted September 30, 2011 The only difference in the dyno setup was the gear used. Anders car was done in 5th gear and KDW in 4th due to higher rev limit and will overspeed dyno in 5th. Kims car does make alot more power low down though due to having higher compression ratio and being 3.4l. It is the highest HP 2JZ i have seen when i did a power run as an normally aspirated which i do on every car i map to get an idea of the VE of the engine to plot a fuel curve. Ryan Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 30, 2011 Share Posted September 30, 2011 awesome car kim (best Supra in EU)..IMO now lets get every big supra owner to a TDI dyno hub for a shoot same day same dyno.. be interesting to see. Link to comment Share on other sites More sharing options...
RZ95 Posted September 30, 2011 Share Posted September 30, 2011 awesome car kim (best Supra in EU)..IMO now lets get every big supra owner to a TDI dyno hub for a shoot same day same dyno.. be interesting to see. Thank you for the nice words That would be awesome, or even a mile event. I would love to do a mile event but I can't seem to find any decent in Europe. Link to comment Share on other sites More sharing options...
RZ95 Posted September 30, 2011 Share Posted September 30, 2011 Double post. Link to comment Share on other sites More sharing options...
Krister Posted September 30, 2011 Share Posted September 30, 2011 I would love to do a mile event but I can't seem to find any decent in Europe. Come to Finland next year. We have mile events usually four to six times a year. No noise limits or safety equipment needed. Link to comment Share on other sites More sharing options...
Westy Posted September 30, 2011 Share Posted September 30, 2011 awesome car kim (best Supra in EU)..IMO now lets get every big supra owner to a TDI dyno hub for a shoot same day same dyno.. be interesting to see. Would love to see that happen! Link to comment Share on other sites More sharing options...
RZ95 Posted September 30, 2011 Share Posted September 30, 2011 Come to Finland next year. We have mile events usually four to six times a year. No noise limits or safety equipment needed. How's the quality of the tracks? Link to comment Share on other sites More sharing options...
RZ95 Posted September 30, 2011 Share Posted September 30, 2011 I could've sworn we did mine in 5th Ryan? That was why we couldn't take it past 8K rpm. I think you did Anders' in 4th actually, could be wrong of course. The only difference in the dyno setup was the gear used. Anders car was done in 5th gear and KDW in 4th due to higher rev limit and will overspeed dyno in 5th. Kims car does make alot more power low down though due to having higher compression ratio and being 3.4l. It is the highest HP 2JZ i have seen when i did a power run as an normally aspirated which i do on every car i map to get an idea of the VE of the engine to plot a fuel curve. Ryan Link to comment Share on other sites More sharing options...
Ryan.G Posted October 1, 2011 Share Posted October 1, 2011 I could've sworn we did mine in 5th Ryan? That was why we couldn't take it past 8K rpm. I think you did Anders' in 4th actually, could be wrong of course. Best to ask the dyno guy mate to check the folder. I honestly cant remember but i think you might be right as i would have to do in 5th to keep the axle torque down. In this case they would have both been done in 5th. Double check with the dyno guy and get him to send a comparison where it shows hp vs ftlb Link to comment Share on other sites More sharing options...
RZ95 Posted October 1, 2011 Share Posted October 1, 2011 Best to ask the dyno guy mate to check the folder. I honestly cant remember but i think you might be right as i would have to do in 5th to keep the axle torque down. In this case they would have both been done in 5th. Double check with the dyno guy and get him to send a comparison where it shows hp vs ftlb It must be 5th because it's doing close to 190 mph at 8000 RPM. http://peecee.dk/uploads/102011/KDW_SUPRA_RACEFUEL_VS_PUMP_GAS_SPEED.JPG Link to comment Share on other sites More sharing options...
RZ95 Posted October 1, 2011 Share Posted October 1, 2011 Here it is with whp vs. ft/lbs for mine and Anders' Link to comment Share on other sites More sharing options...
DARETT Posted October 1, 2011 Share Posted October 1, 2011 Kim, have you got a boost plot as well by any chance?... Link to comment Share on other sites More sharing options...
RZ95 Posted October 1, 2011 Share Posted October 1, 2011 I don't sorry. Link to comment Share on other sites More sharing options...
RZ95 Posted October 1, 2011 Share Posted October 1, 2011 If I can have Ryan send me the log files from when we ran it on the dyne, then I can fix something for you though Link to comment Share on other sites More sharing options...
RZ95 Posted October 8, 2011 Share Posted October 8, 2011 Here's a vid I did today as an attempt to show how hard the car pulls: http://youtu.be/7BqZrcFrZsA?hd=1 Link to comment Share on other sites More sharing options...
JamieP Posted October 8, 2011 Share Posted October 8, 2011 Are you running 28" tyres in that video? looks like you are hitting boost cut in 4th? Link to comment Share on other sites More sharing options...
RZ95 Posted October 8, 2011 Share Posted October 8, 2011 I'm lifting for a split second in 4th due to bumpy road (not intentionally). Yes I'm running 28's Link to comment Share on other sites More sharing options...
