Notts_TT Posted September 27, 2011 Share Posted September 27, 2011 Hi Everyone I have just pulled my supra out the garage after a year of not being used or started and it won't idle, I've cleaned the icv but still no joy. I called a local tuning / dyne company and he also said clean the icv but I told him I've already done this so he asked the last time fresh fuel was put into the car, I told him the fuel in the car was 12 months old and he said something like it's out of date and lost it's va va voom He said this could be the reason for it not starting ???? What do you guys think, it doesn't even attempt to idle at all it just dies as soon as I lift off the revs. Please help. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Steve Posted September 27, 2011 Share Posted September 27, 2011 If the battery has been disconnected the ECU will need to re-learn. Mine would hardly idle if the battery was removed (when stock). If you can hold the revs up for a bit it should sort itself out. If it idles ok, take it for drive for a good 20 mins. Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 27, 2011 Author Share Posted September 27, 2011 Hi, I sat with the revs up, and blipped throttle for 5 minutes, would 12 month old fuel not be the problem here then..? Quote Link to comment Share on other sites More sharing options...
FOSTA Posted September 27, 2011 Share Posted September 27, 2011 Hi, I sat with the revs up, and blipped throttle for 5 minutes, would 12 month old fuel not be the problem here then..? im sure fuel is no good after 6months mate. try and drain it out (but keep it just incase) and put £20 worth of V-POWER in as it has a higher octaine level and see if this works. if your car worked fine before you locked it away i would think fuel is no good after this lenth of time but i could be wrong. hope this helps ;-) Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 27, 2011 Author Share Posted September 27, 2011 Anyone else on the fuel thought ?? Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2011 Share Posted September 27, 2011 Why not just drive it to the petrol station and fill it? You'll find out one way or another Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 28, 2011 Share Posted September 28, 2011 As per Steve, Ive also experienced this, and like Steve I just held the revs up for a few minutes until it stabilised. Not reving its nuts off but up to about 1000 to 1200. Get a jerry can and put some fresh fuel in if you want Quote Link to comment Share on other sites More sharing options...
Havard Posted September 28, 2011 Share Posted September 28, 2011 How much fuel is in it? I would be tempted to either drain it or depending on how much is in there I would fill it up and dilute the existing fuel. The problem with that is you could end up draining the lot and wasting £70 or mores worth of fuel. I would say the fuel is the problem though. H. Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 28, 2011 Author Share Posted September 28, 2011 It's on the red line so it's just about empty, I'll stick some fuel in it today and keep u posted.. Cheers Quote Link to comment Share on other sites More sharing options...
fastnfurious Posted September 28, 2011 Share Posted September 28, 2011 (edited) suggest you remove both ECU and throttle control ECU then inspect the mainboard for possible faulty transistors ie. meltdown, bad circuit. my buddy's Supra had the exact same problem like yours and after checking the fuel pump, relay and all others under the hood, it's finally the ECUs are the culprit and found few transistors leaking juices all over the mainboard... it's fixed now after replacing both ECUs and back in full swing! Edited September 28, 2011 by fastnfurious (see edit history) Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 28, 2011 Author Share Posted September 28, 2011 I wouldn't know what I'm looking at mate, if fuel idea doesn't work I'll leave it to the professionals... Thanks to everyone for there input so far. Dan Quote Link to comment Share on other sites More sharing options...
Abz Posted September 28, 2011 Share Posted September 28, 2011 Once you do get fresh fuel in it, try getting it on a good decent run. Ideally one where you don't need to stop, this will get the engine going & also give the ECU time to re-learn itself. A nice 10/20 mile gentle motorway blast would be good. Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 28, 2011 Author Share Posted September 28, 2011 It's not taxed or mot'd :-( I live in the middle of nowhere so thought I'd just go for a cruise to the next village and back 8 miles away :-) Quote Link to comment Share on other sites More sharing options...
Scott Posted September 28, 2011 Share Posted September 28, 2011 Taking a bit of a risk there bud. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted September 28, 2011 Share Posted September 28, 2011 I'm also fairly sure fuel does go off after a period of a few months. If you go for a run to help the ECU re-learn, I would at some point let the car idle and blip the revs to allow it to learn where the stable idle point is. Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 28, 2011 Author Share Posted September 28, 2011 I know it's a risk with no tax n mot... But roads are dead round here. I'm going to refuel and run it out later, I will let u all know. Thanks Quote Link to comment Share on other sites More sharing options...
Abz Posted September 28, 2011 Share Posted September 28, 2011 It's not taxed or mot'd :-( I live in the middle of nowhere so thought I'd just go for a cruise to the next village and back 8 miles away :-) If you booked it into a MOT garage 8 miles away then that would be fine Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 28, 2011 Author Share Posted September 28, 2011 Good idea, fake booking here I come :-) Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 28, 2011 Author Share Posted September 28, 2011 Right everyone,I put 10 litres of fuel in and I just took it out for a spin and it won't rev, if I keep my foot light on pedal it will move away very slowly but as soon as you try to accelerate it just heavily misfires and bogs out, you can hear turbos trying to spool but they just won't. Trying to drive a auto that won't idle is an art form .... I do feel that this is sh*t fuel still and maybe the octane level is far to low....?? How much fuel is in a tank when needle hits red, maybe it was a 50 50 mix of new and old petrol... Please help someone... Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 28, 2011 Share Posted September 28, 2011 If you are that worried get more fuel, 10 or 15 litres and try it again, personally I think you have other problems. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 28, 2011 Share Posted September 28, 2011 Why didn't you just fill the tank to be sure? I would give the coilpack connectors and spark plugs a quick check to make sure they are OK Quote Link to comment Share on other sites More sharing options...
Abz Posted September 28, 2011 Share Posted September 28, 2011 Why didn't you just fill the tank to be sure? I would give the coilpack connectors and spark plugs a quick check to make sure they are OK 10 litres won't be a huge amount of fuel to balance out the old fuel. I am going with spark plugs if it is just spluttering. Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted September 28, 2011 Author Share Posted September 28, 2011 It's not just spluttering, when you accelerate it totally bogs out as if it's cut out... It revs smooth and clean when in neutral to a high rpm... Abz is there a octain booster or something I could buy to help raise octane levels in the old fuel, or how do you totally drain the fuel tank. Thanks Quote Link to comment Share on other sites More sharing options...
Scott Posted September 28, 2011 Share Posted September 28, 2011 Talking to you is actually really difficult as you don't seem to take anything on board. The octane boosters that you get in the garages will do nothing, take your car to a petrol station and fill it with the highest octane fuel you can find. This will mix with the low octane old fuel you have and get the octane to a good level. If your light was on there is no need to worry about draining the tank. If that doesn't work, pull the spark plugs out and check those along with the coil packs & coil pack connectors. Or are you deliberately ignoring what is being suggested to you? Quote Link to comment Share on other sites More sharing options...
