Scott Posted September 28, 2011 Share Posted September 28, 2011 My apologies for making an incorrect assumption on the vacuum bleeders, must take more time and read all the info before typing next time I've found a vacuum bleeder that appears to be a hand pump and is £40. http://www.simsestools.co.uk/hand-held-vacuum-pump-brake-bleeder-kit-cars-p-154.html That looks the part, looks like plenty of attachments too. Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 28, 2011 Share Posted September 28, 2011 That looks the part, looks like plenty of attachments too. Phew Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 28, 2011 Share Posted September 28, 2011 Mityvac stuff is excellent quality though, I have two Mityvac hand pumps, one vac and pressure, the other just pressure, they've done a LOT of work (and no, I don't mean I've got two inches more length and an inch more girth since buying them.... ), and they are still working as new. I have a pro quality brake pressure bleeder that looks like a Sputnik. It used to get used nearly every day, but nowadays the MC cap adaptors fit hardly any modern cars. Somewhere on my "to do" list is buy some used modern and popular, used MC caps and convert the fittings to them. When you could just plug it onto a MC made brake bleeding solo a joy. Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 18, 2011 Author Share Posted October 18, 2011 Just to update this, I used the tube I have, bled into a bottle with some fluid in already, and had an assistant to work the brake pedal. First one I did (passenger side rear) had a load of air bubbles that you could see rushing through the plastic tube. Got a couple of pumps of solid fluid with no air, and everything is spot on now Quote Link to comment Share on other sites More sharing options...
