dude Posted September 27, 2011 Share Posted September 27, 2011 PHR Solid engine mounts, These are a must for any Supra making in excess of 600 HP! On the chassis dyno, we found that single turbo equipped Supras would move in such a fashion as to push the turbocharger assembly against the shock tower under boost. This resulted many times in a scratched turbo housing and/or cracked exhaust manifold. We also found that the TRD upgrade engine mounts were not sufficient enough to correct this on engines making over 650 RWHP, so we once again turned to PHR for assistance. Constructed from lightweight Chromoly Steel, these engine mounts are coated in the familiar PHR red, and utilize Grade8 1/2" fasteners to corral the mighty 2JZ-GTE. A direct replacement for the stock engine mounts on the 1993-96 Supra and a standard item on any PHR race engine. If you have a 1997-98 Supra you will need to purchase the same 2 Toyota adapter pieces required to fit the TRD engine mounts onto a 1997+. You can purchase these from Toyota or MVP, just contact us for pricing & availability. Highly recommended and found on all 3 MVP Supras, including our retired 8 second drag car, our street car with 180,000+ miles, and our road-race Supra. £100 + p&p Link to comment Share on other sites More sharing options...
dude Posted October 2, 2011 Author Share Posted October 2, 2011 Bump Link to comment Share on other sites More sharing options...
JamieP Posted October 24, 2011 Share Posted October 24, 2011 I will take them if you still have them mate. Link to comment Share on other sites More sharing options...
dude Posted October 24, 2011 Author Share Posted October 24, 2011 OK dude, ill stick em in a drawer. Link to comment Share on other sites More sharing options...
