Monster supra Posted September 25, 2011 Share Posted September 25, 2011 Hello guys Getting error code 55 I found out it is the crank knock sensor (rear) either not connected or a short connection Can someone tell me where its located on the engine The supra is a 1995 jap spec N/A Auto mk4 Any help or suggestions welcome Also how do you reset the ecu memory to wipe out the error code Link to comment Share on other sites More sharing options...
TT Paul Posted September 26, 2011 Share Posted September 26, 2011 reset ecu pull one of the 30 amp fuses in front box for 10 sec not which one, or disconnect battery earth... Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 26, 2011 Share Posted September 26, 2011 Arrowed in the photo of an engine I built, they are quite expensive new,and a risky buy secondhand: Link to comment Share on other sites More sharing options...
Monster supra Posted September 27, 2011 Author Share Posted September 27, 2011 Thank you guys Hope I can fix it Might just be loose when I put the engine back together. Will post up the results Link to comment Share on other sites More sharing options...
